not a truck but it is a truck motor
Old 02-24-2009, 09:03 PM
  #101
built408's Avatar
hahahahahaha
Old 02-24-2009, 09:05 PM
  #102
nonnieselman's Avatar
Originally Posted by parish8
waiting on the driveshaft and a couple of fuel line fittings. it is real close to being ready for the dyno.
You better have us some video, you know we dont have anything else better to do..
Old 03-05-2009, 01:19 AM
  #103
AaronL's Avatar
we tried a few ways of deflecting the fuel to help it dispurse better and it helped. reflecting the fuel with a small plate so it ended up shooting almost strait up got it running the best so we welded 4 small plates right in front of the injectors.
.....now it starts and ildes and revs well on the 4 elbow injectors.
Jim,
Do you have any pictures of how you re-distributed the fuel spray better on the elbow's injectors? I'd like to see how you did it for future elbows. I've had a few guys want some similar to yours, but I'd like to get a better plan on positioning the injectors.
Check these pics out:
It would be nice if there was a company out there that makes/modifies injectors that specifically spray a really wide pattern for placement other than pointing directly at the intake valve.
The wagon is looking bitchin' man, good work.
Old 03-08-2009, 01:26 AM
  #104
single digit dreamer
parish8's Avatar
hey aaron. we didnt get any pics. our aluminum welding skills suck, we didn't want to post up pics of out nasty tabs welded to that killer looking elbow. all we did was weld a 1/2" x 1/2" square tab right in front of the hole. the fuel stream hits the tab almost squarely but is deflected up maybe a little. runs good now.
we did try a few diferent injectors. one of wich is suppose to have a wide pattern. one set was "try cone", another set had 6 very small holes. first set was just one large hole.
Old 03-08-2009, 01:33 AM
  #105
parish8's Avatar
got a few new pics.
Old 03-08-2009, 01:40 AM
  #106
GMCtrk's Avatar
Can I get some details on that 4l80e converter you are running?
Old 03-08-2009, 09:43 AM
  #107
How do I change this text
Wilde Racing's Avatar
Looks like the same trans cooler that killed my tranny...
WTH is the do-hicky next to the BOV?
Old 03-08-2009, 10:48 AM
  #108
parish8's Avatar
please explain the cooler thing. why do you think it killed your tranny? i have used this cooler on several projects now with no issues.
that is in extra injector. we wanted to put a pair up stream to help give the meth time to work. i dont know if it will help but if nothing else it will give us a little more capasity with our fuel system. there will be 10 alcohol injectors.
Old 03-08-2009, 11:04 AM
  #109
parish8's Avatar
ohhh soo pretty >> https://ls1tech.com/forums/automatic...sk-billet.html
Old 03-08-2009, 11:14 AM
  #110
I'm the only one that I've heard of that had an issue with the cooler.
On the way home from work one day, my trans got up to 250 deg. I got it home and idled the truck in park, trans oil temp went up. I quickly pulled the grill, used a water hose and soaked the cooler (while still idling) That is when I noticed the water boiling off one line and not the other. Touched the line with my hand it was COLD. Long story short, trans cooler plugged and it took the trans out.
Quick Reply: not a truck but it is a truck motor
