not a truck but it is a truck motor
#113
How do I change this text
Every once in a while it would make a noise while backing up after the over heat. Trans didnt actually let go until about 5 months later...
Reaction carrier planet died, lack of oil. Plates and disks looked good, trans was pretty clean.
Like I said, I'm the only one I've heard of, but I personally will never buy another aftermarket plate style cooler.
The car is BAD ***, got any more pics of the inside?
#114
yeah, we could have planed that better but that is how it worked out. i have seen many alkey injection set ups that sprayed before the bov including my truck. there wont be a lot of fuel. i will let you know if it blows up.
we wanted to get a little fuel upstream of the intake to give it time to cool the charge air.
#116
it would mess up the look if we did that. i am not too worried about it. it wont be spraying much meth at all. it will be all vapor and shut off as the tb is closing. considering the air will be hot and a large volume of it and just one injector i think the mixture will be real thin and not even visable when it blows off. those injectors will only be on above 5psi.
on the flip side if we see fuel spraying out when we let off then i will re work it.
#117
got our first vid. nothing special, almost ready to drive >> http://www.neufamily.org/vids/novavids/1stnovavid.wmv
got some stickers on the car
