not a truck but it is a truck motor
Old 05-03-2009, 03:46 AM
  #151
GFYS and STFU
Spoolin's Avatar
Is that still stock cubes? 6L right?
Old 05-03-2009, 07:57 AM
  #152
single digit dreamer
parish8's Avatar
completely stock other than a 2002 zo6 cam, patriot gold extremes and i think we did pushrods.
Old 05-03-2009, 06:41 PM
  #153
parish8's Avatar
in a week or two we should have a chart with the dual fuel change over to race fuel and then do another where we change from pump to meth. should be some neat info. looking at that chart we might need to spin it a little higher
Old 05-03-2009, 06:55 PM
  #154
9 Second Truck Club
stock48's Avatar
Originally Posted by parish8
very fun day at the dyno today. we suspected a problem with our 2nd fuel system and to confirm this we wanted to just tune the car on that system. sure enough it wasn't tuning well. sounded like it was running on 4cylinder once we got off idle. heat gun confirmed this. dynotom busted out his hand held duel trace scope and hooked up to one injector on each bank and right away showed we were not geting the "peek" of the peek and hold on one bank. ******* squirt this made us very happy since now we know what our problem is.
the phased fuel is going to be easy and work well once we get that fixed.
just to have some fun and to test out the rest of our 2nd fuel system we hooked up the injector harness from our primary fuel system to our 2nd fuel system and made a few runs. this means we were running off of only the 8 injectors that are higher up in the runner and we were running off of the big fuel system and on race gas. even though the car will never idle on these injectors it still idled pretty good and was easy to tune.
numbers... 508rwhp(mustang) at 10psi, no intercooler, 214deg peek iats. this was on race gas. we plan on running on meth, not race gas. meth should be good for AT LEAST 50rwhp more at the same boost level. at 10psi i think we are headed for 560+rwhp.
just for refrence the fairmont with an intercooled 5.3/mp70 and the same cam as we are running now was at 458rwhp@10psi on the same dyno. different tranny and converter but it is fun just to compare.
very fun day and thanks to tom at c@s
Methanal might be worth more than 50RWHP once you turn the boost up. I have seen supercharged cars pick up a full second from gas to alcohol. What year 6.0L is that?
Old 05-31-2009, 04:00 PM
  #155
skolman91's Avatar
updates?
Old 05-31-2009, 04:05 PM
  #156
parish8's Avatar
the engine is suppose to be an 01 but who knows.
nothing new to report. got sidetracked on some other stuff. the car is ready to go back to the dyno and try the duel fuel and then duel fuel meth but now it is blocked in the garage. i have only had 1/3 of my floor poured since last year and now i have the other 2/3's ready to pour but they are not coming to do it till next weekend so the car is blocked in by the rebar and floor heating pipes.
Old 05-31-2009, 05:20 PM
  #157
ZR1 DREAMING's Avatar
So wich are you more excited to finish, the car or the garage?
Old 05-31-2009, 06:20 PM
  #158
parish8's Avatar
definatly the garage. i have been out there almost every day doing something. i think it will be "done" in a month or so. that does not include the fun stuff like finishing off the inside, bathroom, loft, stripper pole, lift, work bench...
Old 05-31-2009, 06:31 PM
  #159
blownerator
BlownChevy's Avatar
definatly the garage. I have been out there almost every day doing something. I think it will be "done" in a month or so. That does not include the fun stuff like finishing off the inside, bathroom, loft, stripper pole, lift, work bench...
lmfao:d
Old 05-31-2009, 06:38 PM
  #160
Cool, sounds fun man... I can't wait to tackle a project like that once I finally settle down in some nice land.
Quick Reply: not a truck but it is a truck motor
