not a truck but it is a truck motor
Old 08-08-2009, 01:53 PM
  #201
GFYS and STFU
Spoolin's Avatar
Sounds like a blast!!! So nitrous for the launch, switch back to meth and see how all that does and then what?
Old 08-08-2009, 01:55 PM
  #202
single digit dreamer
parish8's Avatar
add boost. the turbos are barely working.
Old 08-08-2009, 01:56 PM
  #203
GFYS and STFU
Spoolin's Avatar
Old 08-08-2009, 04:50 PM
  #204
OnyxSilveradoSS's Avatar
Originally Posted by parish8
john the computer geek has a touch pad mounted in the car that shows mph, gear, trans temp, engine temp, rpm.
do you have any pics of that??
Old 08-15-2009, 02:13 AM
  #205
parish8's Avatar
fun night at the track tonight. boost controler is working now so we went ahead and turned it up a little.
10psi was around 6.85@102, 1.65 60'
13.5psi gave us a best of 6.54@106.7 with a 1.61 60'
this is on the e85 still. next step is to spray it off the line and see how it responds. we are leaving with as much brake stall as we can and that is still just 0.5psi or so. a 100 or larger shot should get it moving in a hurry. next trip to the track we will take the wheely bars just in case we need them.
Old 08-15-2009, 04:26 AM
  #206
GFYS and STFU
Spoolin's Avatar
WOW!!! 1.61 60' times while leaving with 0.5lbs of boost!!!
How do you do that!!! Very impressed and congrats!
Old 08-15-2009, 07:09 AM
  #207
LsxCody's Avatar
That is pretty good
Old 08-15-2009, 10:43 AM
  #208
parish8's Avatar
the boost is on it's way up and comes on hard just 10-20feet out.
also this is a camed 6.0 in a 3000lb car with a 3000+ converter. it should get off the line ok without any boost.
Old 08-15-2009, 04:39 PM
  #209
parish8's Avatar
here is a screen shot of our last run for anyone interested. you can see the 2 ve tables. the pw1 and pw2 and you can see it switch from one to the other mid run and then switch back when we let off. the transition could use a little more help but as bad as it looks on the wideband it is smooth in the car.
Old 08-15-2009, 05:18 PM
  #210
How do I change this text
Wilde Racing's Avatar
Is there some type of multiplier for the higher second table?
Congrats on the times and the success of the project so far..
Quick Reply: not a truck but it is a truck motor
