Oakley's History Lesson and Build Thread
Old 02-05-2014, 05:09 PM
  #391
ak2007r6's Avatar
Out of all the money and time I've put in this truck, the auto meter cluster is probably my favorite investment. I know that sounds stupid but it was a blast figuring out how to build the cluster to look like stock, wiring everything to work with the pcm, ect. And anyone I show the truck to just wants to talk about the cluster I could have an 8000hp funny car engine under the hood and people would be shocked about the cluster. Its stupid
I haven't found any negative. You won't have blinker indicators, and all the warning stuff but that was never an issue for me. I'm under the hood enough to know if the coolant is low, oil is low, ect.
Will have to start figuring out how I want it laid out and what gauges will look best. For turn signals I figured I could put a couple small LED"s if I really wanted to. Wouldn't be hard.
Are you able to program the odometer on the Autometer gauges??
Old 02-05-2014, 05:47 PM
  #392
lycominghunter's Avatar
Looks like you found out that Earl's performance piece is a swivel just got my box from summit today. I cut my assassins, but I have helper bags on the back so I'm not too worried about the weight carrying concern. Did you get to test fit the Hi-ram to see if there's enough room between the fuel rail and alternator?
Old 02-05-2014, 09:14 PM
  #393
oakley6575's Avatar
AK, yea it's simple to wire in some blinkers. I just wanted mine to be as simple as possible. And no on the odometer. Your truck will have 0 miles when you are done with the install. The only thing you can program is the pulses per mile. So it shows the correct mph.
Ly, I'm not going to put the intake on until I finish ordering my fuel parts. Should be a few weeks.
Old 02-05-2014, 09:17 PM
  #394
I want to start ripping it apart, but the truck hasn't been up for over a week yet...HA. I'm interested to see the difference from a stock intake/tb to the hi-ram/90mm tb.
Old 02-05-2014, 09:50 PM
  #395
oakley6575's Avatar
Difference in what? Power wise you mean?
Old 02-06-2014, 04:27 AM
  #396
Yes. I'm sure there'll be an improvement I'm just not sure how much on NA 4.8l...we see
Old 02-06-2014, 10:21 PM
  #397
oakley6575's Avatar
I need some help from you brilliant drag racers.
I was launching my truck the other day after the assassin bar install. Right now I have the 2 step set to 2800rpm I think. If I stand on the brake, and get it up on the 2 step, I can build 5-7psi. But since the traction bars went in, the rear of the truck climbs up before launch. This isn't something I want to happen right? Don't I want it to hit the tire hard at launch instead of already loading the suspension? Any help would be great guys!
Old 02-06-2014, 10:49 PM
  #398
I have a gauge for that
Atomic's Avatar
You dont want to shock the tires and loose traction, which is what happens when the suspenion loads and unloads quickly. If it spins you need to work on your shocks or how you ramp in the power.
Old 02-06-2014, 10:53 PM
  #399
oakley6575's Avatar
So the rear end climbing is something that I want? I've been watching a bunch of vids and haven't seen that on any of them.
Old 02-06-2014, 11:19 PM
  #400
Atomic's Avatar
Yep. To push something up means you have to apply force downward. Look at funny cars or promods.
Quick Reply: Oakley's History Lesson and Build Thread
