Oakley's History Lesson and Build Thread
#803
I went through the reservoir over the weekend and refilled it yesterday. Then I went out and did some testing at 16psi last night. So I've probably used around 2 gallons so far. Tuning is easier with e85 but fuel mileage is back where it should be with the pump gas. I like the meth and it will be a lot easier to hit my goals using it.
#808
Also during previous 1/4 times are you passing in 3rd gear with 4.10s and at what rpms?
#809
As far as MPG, I have no idea. I romp on it way too much to care about it. Only way I will keep track of mpg's is if I take it on a road trip. I did get off of ethanol because of the mpg's but I don't know if it was getting 12mpgs or 5mpgs. All I know is that it would run out of gas far too often
#810
haha maybe I should have asked mpt "miles per tank"
That's what everybody wants to achieve right?...to be passing the finish line in 3rd at peak performance. I was thinking if you raise the boost up do you think you might start shifting into 4th with the 4.10s?
