OBS 97 Z71 05 5.3 and Radix Swap
Old 02-12-2010, 07:37 PM
  #91
exodus's Avatar
intercooler to tank or to blower? and from blower to where?
Old 02-12-2010, 07:45 PM
  #92
what a rush!
moregrip's Avatar
upper barb is the entry point to the tank so that hose would be coming from the blower; the lower barb is the exit point so from there it would go to the I/C pump (about a 3-4" length of 3/4" heater hose), then from the I/C pump to the H/E, then from the H/E to the blower.
Old 02-12-2010, 07:52 PM
  #93
exodus's Avatar
Ok, thanks...I will snap some pics of the wiring and post it here in a few so you can see what I have here.
Old 02-12-2010, 08:02 PM
  #94
exodus's Avatar
Default The wiring I have...
Here are the two small harnesses I have
The 3 relays with open pins???
And a closer shot of each...
Old 02-12-2010, 08:22 PM
  #95
what a rush!
moregrip's Avatar
the white wire is the power wire and plugs into relay #1, center location, looks like the connector is still on it. The black wire is a chassis ground.
Old 02-12-2010, 09:04 PM
  #96
exodus's Avatar
and that is the one for the pump right?
Old 02-12-2010, 11:19 PM
  #97
james8997's Avatar
also, whats 'pinning the crank' mean? and what is the reasoning?
Old 02-12-2010, 11:22 PM
  #98
11 Second Hall Moniter
AKlowriderZ71's Avatar
Here's some good reading for ya!
https://www.performancetrucks.net/fo...d.php?t=415160
Old 02-12-2010, 11:40 PM
  #99
james8997's Avatar
Originally Posted by AKlowriderZ71
thats exactly what i was thinkin, to prevent the pully from slippin, thanks man
Old 02-13-2010, 08:48 AM
  #100
SuperchargedSS's Avatar
if you download a copy of the install manual for the magnacharger, you can pretty much figure out the hose routing from there on. Although Grip did a pretty good job of explaining it already. Even the wiring is identical with the exception of 1-relay vs 3-relays.
When I had Grip's blower, that is what I did. Followed it to a "T" and it worked very well. All in all the install was fairly easy with his setup.
Did you find out where the polished fuel rail went?
Quick Reply: OBS 97 Z71 05 5.3 and Radix Swap
