Polished Vic Jr, Fast 4150, and 2/4 drop
#32
Got my trans all put in tonight. also got my throttle linkage done the way i imagined it to be. just waiting on some manifold gaskets to get it running
#34
Heres what Im going to do with my throttle cable. I have a 1/4 heim end. The 1/4 sae bolt I put in my lathe and drilled a hole the size of my throttle cable all the way thru it. On the other end is a bigger hole. Im going to make my bracket first that throttle cable will bolt to on the back on the intake. Then cut the cable to length, thread it thru the bolt, fold a 1/4 in and pull it tight into the bolt and pour some lead in there to hold it tight.
#39
Heres what the linkage is gonna look like.. bracket is just settin there, its the 3rd time its been welded to accommodate the intake its been on. The cable is adjustable.
Flux Core Welder FTW
Heres what Danny and I got accomplished today. The rear consists of the 2 inch shackles and 2 in hangars and load level spring taken out. Fronts consists of 1 coil cut out. Pretty simple and pretty cheap.
