potato land build, 9's@140+ is the goal
#91
It looks like a tight fit from this angle for any dp much less a 5" one....I have a 5" one and it took a magician to fit it, and I dont have AC parts in my way, so I hope you have some skills!
The Vbands my welder used are from here Vibrant Performance ::. they have a little flange area on them so they fit inside one another and not leak. Without that, I bet you will have leak issues, especially holding all that weight.
i like those v-bands you got , wish i would of saw those b4 i got all of this welded . how will those o rings take the heat thou ? if all else fails i can make so gasket for them i guess, but i think the brace should take allot of the weight off the pipes . do you have one of those huge intake elbows ? if so could you measure how much distance it takes before it goes full 90 degrees, i need to know if i can fit it within a 8" space.
#92
Good luck with the build man. Looks good so far. I was planning on doing a flipped manifold build similar to yours, but I switched to a kb log. Mocked it up and everything, but didnt like how it fit. Also, I dont think im half the fabricator I need to be to pull that off. Keep us updated. I want to see some
#93
I have a gauge for that
yeah its going to be tight for sure. i got almost 12"s from the back of my turbo to the ac drier and got exactly 5" from manifold to fender inner liner . so the inner liner is going to probably get shaved a lil bit and the ear on the manifold is going to get grinded off also.
Yea I have a big elbow, and had to cut the **** out of my fan shroud and the elbow to get it to fit. Kind of hard to see in this pic but...
#96
looks like im in for another tight fit ... lol . my turbo sits more to the left then yours and it kinda points toward the corner so if i were to put that elbow on it, it would go straight into that hole that your second one goes into .i might need to heat it up and ovalize it a lil bit cause i think all i got to the rad. support is about 8".
