potato land build, 9's@140+ is the goal
Old 05-09-2013, 12:00 AM
  #71
I have a gauge for that
Atomic's Avatar
Ah, haha lot of work for that pic! Is that where you are going to place it when you make your pipes?
Old 05-09-2013, 12:28 AM
  #72
idahoblkss's Avatar
yeah close to that but it will be a lil higher and slightly angled toward the block to help point the exhaust in the right direction.
Old 05-09-2013, 10:30 PM
  #73
idahoblkss's Avatar
Picked one of these up. It can do boost by gear which I think will come in handy and also can completely control your nitrous system !! Sweet!
Old 05-24-2013, 11:59 AM
  #74
idahoblkss's Avatar
ok ill have some new pics here soon should have all of my pipes tacked up tonight / tomorrow ready to get tig welded.so i finally got my jgs 50mm wg in the mail but it didnt come with any literature . what are the springs set to from the factory ? if any body could give me a lil insight on this unit i would appreciate it.
Old 05-24-2013, 12:35 PM
  #75
GMCtrk's Avatar
Mine came with 2 springs. The spring preinstalled in the unit is the lighest spring. In my setup it gives 6-7 psi with a peak of 8.5.
Old 05-24-2013, 02:03 PM
  #76
idahoblkss's Avatar
did you try the other spring ? if so what did it put you at?
Old 05-24-2013, 02:10 PM
  #77
Atomic's Avatar
weak spring is around 7, stiff spring around 12, both around 19
Old 05-24-2013, 03:23 PM
  #78
idahoblkss's Avatar
perfect ! thank you ! where do you buy lil stiffer springs to say get to the mid 20's ?
Old 05-27-2013, 02:37 AM
  #79
idahoblkss's Avatar
Getting closer...
Old 05-27-2013, 03:02 AM
  #80
ak2007r6's Avatar
Nice build. Curious to see how this does over the Procharger setup.
Quick Reply: potato land build, 9's@140+ is the goal
