Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1041
Originally Posted by Richard@WCCH
Don't forget to torque those bolts to a quarter turn past strip We don't want have bolts falling out upon launching.
Clean setup here Grip. Making some progress I see. Have you got a timeline on stabbing the engine and trans in?
Richard
Richard
#1042
FormerVendor
Originally Posted by moregrip
Holy ****! just when I thought I'd have to rig something to fit I find these buggers in the back of my hardware supplies.......frigging AN960 washers!
Oh hell yeah!
what's an AN960 washer you ask?
AN960 flat washers are used under hex nuts to provide a smooth bearing surface, as shims to obtain the correct grip length for a bolt and nut assembly
in this pic you can see the bag of hardened washers I had (to big @ 1/2"), then you can see the 3/8 and 7/16 grade8 washers I was getting ready to use, and lastly, in the front the 7/16 AN960 washers that fit perfectly , but I still have to double stack them to achieve the correct thickness, looks good to me, any differing thoughts before I wrap this dilemma up?
pic of the AN960 washers in action:
each washer is .063 thick so I needed approx .126 worth of spacing.
I may try and find a single washer in that thickness rather than running two....
OD of the ARP bolt is .0472
ID of the AN760 washer is .0551
Oh hell yeah!
