Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 03-08-2007, 07:25 AM
  #1091
8ALTNG's Avatar
Sounds good Grippy. I sm really looking forward to seeing how this thing runs when it is all over. I just hope that you arent disapointed becuase the Magna doesnt make enough power and you realize you shoudl have gone turbo
j/k man
Old 03-08-2007, 04:14 PM
  #1092
GFYS and STFU
Spoolin's Avatar
j/k man
Old 03-17-2007, 12:26 PM
  #1093
what a rush!
moregrip's Avatar
j/k man
I sure hope I'm happy with it, as long as its taken me
After I have it setup the way I am going to run it daily, pulley selection, tuning, any misc issues.....
I'll be happy with 550/550 ish, thats kinda where I've set my expectation. If it doesn't make 500/500 ish I will be disappointed. Anyhting above 575/575 is icing on the cake
the final criteria for this build, and probably the most important, is, I don't want to have to adopt any special driving habits. In other words, get it, turn the key and go. I'm hoping for a very trouble free end result
Old 03-17-2007, 04:26 PM
  #1094
dhpro's Avatar
Originally Posted by moregrip
thanks Steve, only that the flare tool I ordered/needed showed up today and I'll be able to finish the fuel system this weekend, probably looking at mon-tues after work to drop the engine tranny in
Grip, what fuel upgrades u doin? I already have the walbro in tank unit from the MP112 install, and will add a boost-a-pump to that...I fig that shud be plenty. Only question I still have is the pulley ratio...what idler size shud I run v the OEM pulley on the MP122 and shud I adjust the crank pulley as well? My assumption was to run the standard LS1 stock size on the crank and just transfer over the idler setup from the 5.3/MP112 I already have...may BC has an opinion?
Old 03-17-2007, 04:46 PM
  #1095
what a rush!
moregrip's Avatar
I would just re-use the idler pulleys from your current setup. You could step up to some metco 100mm idler pulleys if you wanted to though.
What pulley did you order with the 122?
My fuel system is a walbro intank fuel pump, KB Boost a Pump, and 60lb injectors rated @ 3bar.
Old 03-17-2007, 05:16 PM
  #1096
what a rush!
moregrip's Avatar
washed and waxed her today, LOL, anyone ever wash and wax a shell of a truck?
here's the business end of it:
Old 03-17-2007, 05:25 PM
  #1097
dhpro's Avatar
Same as me then...didn't specify...but Brian knew what I was up to and told me he'd look after it...I'll open the box later and dbl check and post it tonite. I have a 2.9 in reserve, and 1st glance told me it was a 3.4. R/
Old 03-17-2007, 05:27 PM
  #1098
dhpro's Avatar
Looks lots nicer there than here! We got 6" of sleet last nite then it froze...sure is a purdy lookin' environmentally PC machine right now...LOL!
Old 03-17-2007, 05:43 PM
  #1099
ZR1 DREAMING's Avatar
One of the cleanest motorless trucks I've seen
When's the next progress report due?
Old 03-17-2007, 07:29 PM
  #1100
what a rush!
moregrip's Avatar
question:
do I need to connect this back on the tranny or can I just cap the hard line on top of it?
also, any ideas on what I should torque the crank bolt too?
I was thinking about 100ftlbs
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
