Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1093
Originally Posted by 8ALTNG
Sounds good Grippy. I sm really looking forward to seeing how this thing runs when it is all over. I just hope that you arent disapointed becuase the Magna doesnt make enough power and you realize you shoudl have gone turbo
j/k man
j/k man
After I have it setup the way I am going to run it daily, pulley selection, tuning, any misc issues.....
I'll be happy with 550/550 ish, thats kinda where I've set my expectation. If it doesn't make 500/500 ish I will be disappointed. Anyhting above 575/575 is icing on the cake
the final criteria for this build, and probably the most important, is, I don't want to have to adopt any special driving habits. In other words, get it, turn the key and go. I'm hoping for a very trouble free end result
#1094
Originally Posted by moregrip
thanks Steve, only that the flare tool I ordered/needed showed up today and I'll be able to finish the fuel system this weekend, probably looking at mon-tues after work to drop the engine tranny in
#1095
Originally Posted by dhpro
Grip, what fuel upgrades u doin? I already have the walbro in tank unit from the MP112 install, and will add a boost-a-pump to that...I fig that shud be plenty. Only question I still have is the pulley ratio...what idler size shud I run v the OEM pulley on the MP122 and shud I adjust the crank pulley as well? My assumption was to run the standard LS1 stock size on the crank and just transfer over the idler setup from the 5.3/MP112 I already have...may BC has an opinion?
What pulley did you order with the 122?
My fuel system is a walbro intank fuel pump, KB Boost a Pump, and 60lb injectors rated @ 3bar.
#1097
I would just re-use the idler pulleys from your current setup. You could step up to some metco 100mm idler pulleys if you wanted to though.
