Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1112
WHOOOO HOOOOO!!! i'm done! hadnt looked at this since page 7 or so until last night (at page 7 i thought eh, he'll procrastinate another year and a half and forgot about it )
ive only got 2 things to say though: Holy long thread Batman! and Grippy awesome writups and best of luck with the rest!!
ill be checking in more often now
#1113
got a few things done today, flexplate (80ftlbs) & crank bolt (150ftlbs) torqued down (red loctite on both) (30w motor oil under the head of the ARP flexplate bolts, GM high pressure lube under the head of the crank bolt). Also re-flared the stock fuel line (37deg, looks much better now); all I need is a few AN fittings, some hose, and a filter and I'll be good to go for the fuel system.
if you look closely you can see the kent moore crank holding tool inside the window of the flexplate
#1116
Originally Posted by '89ChevyMadneSS
nice work on the fuel lines.
did you find the tq spec on the crank bolt or is that just what you set it at? either way my money says that sum bitch isn't coming out!
#1118
Read somewhere that GM's insistence on tightening the devil out of the crank bolt was to ensure the pulley was seated all the way onto the snout. Of course Grip's setup is different. BTW thanks for the info Grip. It's due to arrive tomorrow.
#1119
