Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1146
When I did mine(although it's a 60-E), I pushed the converter all the way in on the trans till it made a solid (clunk). When I put the trans in, the mounting points were about 3/16" apart. I just gently pried the converter out till the gap closed, and it went together fine. So far, so good, no noises, rattles, sparks........yet!
#1148
Originally Posted by Richard@WCCH
If it spins freely with the bellhousing bolted up you should be good to go. Good work so far Grip.
Richard
Richard
does the converter need to be fully seated other than to allow enough clearance to bolt her up, because ultimately it would be brought back off the fully seated position when torqued down. thoughts?
#1150
I still think your fine ... especially since I am very confident you have the converter correctly seated in the tranny. You are a pioneer here... no one has your setup but once you are done I am sure others will follow I would give a shout to the flywheel and torque converter manu tomorrow morning. As long as nothing was forced... I still think you are golden! Carry on
Bill
Bill
