Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 03-29-2007, 08:21 PM
  #1141
11 Second Truck Club
bluecajun5.3's Avatar
once you have the bellhousing bolted down to the block and
as long as the bolt aren't too long, then i don't see a problem.
Old 03-29-2007, 08:25 PM
  #1142
what a rush!
moregrip's Avatar
either the converter is not fully seated or the billet flexplate is dead-nuts accurate, I'm not sure which it is yet.........I did feel confident it was seated though
Old 03-29-2007, 08:30 PM
  #1143
Bill Reid's Avatar
I would think if you can spin it... you're good
Old 03-29-2007, 08:38 PM
  #1144
what a rush!
moregrip's Avatar
thats what I'm thinking too, but I don't want to leave it to chance
Old 03-29-2007, 08:47 PM
  #1145
what a rush!
moregrip's Avatar
if it helps there is 7/8" distance from bell housing surface to TC mounting surface
Old 03-29-2007, 08:56 PM
  #1146
wkdivr's Avatar
When I did mine(although it's a 60-E), I pushed the converter all the way in on the trans till it made a solid (clunk). When I put the trans in, the mounting points were about 3/16" apart. I just gently pried the converter out till the gap closed, and it went together fine. So far, so good, no noises, rattles, sparks........yet!
Old 03-29-2007, 09:00 PM
  #1147
FormerVendor
Richard@WCCH's Avatar
If it spins freely with the bellhousing bolted up you should be good to go. Good work so far Grip.
Richard
Old 03-29-2007, 09:03 PM
  #1148
what a rush!
moregrip's Avatar
Richard
good deal Richard, some of my thoughts are:
does the converter need to be fully seated other than to allow enough clearance to bolt her up, because ultimately it would be brought back off the fully seated position when torqued down. thoughts?
Old 03-29-2007, 09:07 PM
  #1149
wkdivr's Avatar
It should be brought off it's fully seated position when you mate the converter, and flexplate, that way you don't put undue pressure on the pump.
Old 03-29-2007, 09:08 PM
  #1150
Bill Reid's Avatar
I still think your fine ... especially since I am very confident you have the converter correctly seated in the tranny. You are a pioneer here... no one has your setup but once you are done I am sure others will follow I would give a shout to the flywheel and torque converter manu tomorrow morning. As long as nothing was forced... I still think you are golden! Carry on
Bill
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
