Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1162
Originally Posted by Bill Reid
Very cool... I'm off Wednesday, Thursday, and Friday, next week... just give me a shout if you need a extra set of knuckles ... it would be an honor to make the drive.
Bill
Bill
#1164
Originally Posted by moregrip
will do bro, might not have any time next week, crossing my fingers
FYI... umongst other things I am considering an LS7 crank for the LS6 block. Assuming I do that I won't need such a long nylon spacer
Keep in touch bro... I am 6 hours away.
Bill
#1165
Originally Posted by 1SlowHoe
No directions with the bolts? Moly lube?
I was hoping to stab the motor in tonight but I guess that will have to happen tomorrow instead, it's all good, it'll give the loctite time to setup
#1166
something else I was working on, not that big of a deal really, but here it is
as you know I have a custom exhaust; so there are many cuts and such that need to made that are not the same as production type stuff, example:
nice clean production cut/notch:
bandsaw cut/notch:
my idea of an improved bandsaw cut/notch:
bandsaw cut/notch:
#1167
here is the appropriate clearance:
I was able to sneak in another 1/4 quart of tranny fluid into the TC as well, woot woot!
That looks about perfect! Just slide the converter up to meet the flexplate, and you should have the correct clearance away from the pump. Lookin good!!!
Check your PM's when you get a chance
#1169
FormerVendor
The first pictures of the tc to flex plate were scaring me. It looks like you got it now. I will say that I have found with the billet shaft and the PI converter that the lockup oring needs to be lubed very well and is sometimes really hard to get the tc in all the way. Trust me when I say that I have cut a couple of orings installing the converter. I use a grease stick from sonnax called a slippery stick. It is very similar to door-ez. sp. It makes it much easier to install with your setup. Vince
#1170
