Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1242
grippy,
Did you call and talk with ATI about the P/S pulley? Considering they have an 8-rib harmonic balancer for the trucks I would have thought the power steering pulley would have been a non-issue... or at least they had a solution in place already. I wonder if the 3/4 ton trucks have a different power steering pump with a larger diameter shaft...
Bill
Bill
#1244
Originally Posted by Bill Reid
grippy,
Bill
Bill
If someone wanted to give ATI a call and report back that would be cool
Whatever happens, it will be a non issue in the long run because it just needs a little machining to get it to work anyway..................from what I can see, it will line-up just fine with the rest of the pulleys, which leaves the blower as the final test fit for this whole 8-rib conversion
#1246
Have you heard from ATI on the power steering pulley?Mine was also smaller than the shaft and I'm sending the pump and pulley to the machine shop on monday.I also discovered I need a shorter snout extension from Whipple.
#1247
Maybe you can help me out, they need a measurement of the power steering shaft to .0000, can you verify my measurement? I got .7500, I sure would like a second set of eyes.
Whitt, whats your email addy, I'll forward you my correspondence
#1250
Those pullies probably have about .005" of press. Meaning the pulley is machined .005" smaller than the shaft. But my guess .0005" of tollerance on the machining would be plenty concervative.
You know a Machinist Mate would have had this thing running weeks ago.
