Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 04-29-2007, 08:47 PM
  #1361
what a rush!
moregrip's Avatar
I double taped all inlets to the blower rotors; first layer is the green no residue stuff the body shops use, outer layer is gorilla tape, double thick, double sticky
Old 04-29-2007, 08:48 PM
  #1362
what a rush!
moregrip's Avatar
Originally Posted by 2005SSR6Speed
Looks great Bro, now I can make sure it all gets polished up real nice for you. I will drop it off on Tuesday.
all boxed up, see you in a little bit
Old 04-29-2007, 08:52 PM
  #1363
FormerVendor
leftcoast32's Avatar
Sounds great, I dont think that tape is going anywhere.
Old 04-29-2007, 09:31 PM
  #1364
2nd fastest 5.3 ECSB
trever1t's Avatar
I can't believe the tape held up to that chem strip. What'd you use Jasco?
Doesn't all the hardware have to come off for the polish? Looks great, and like said above you have done a meticulous job, well done!
Old 04-29-2007, 10:00 PM
  #1365
what a rush!
moregrip's Avatar
thanks bro I try to do everything the right way, at least what I consider to be the right way
the hardware will be fine because those bolts are getting replaced with ARP SS 12pts, in fact, the the whole blower/manifold/J-Tube/TB setup is getting them.
I used Aircraft Stripper, not as strong as I remember it being, but it got the job done just fine none-the-less.
Old 04-29-2007, 11:52 PM
  #1366
what a rush!
moregrip's Avatar
parts are with Joe now, schwing!
Originally Posted by Brian@JPA
all you need to do now is figure out how to beat me
something like this but with more wrinkles in the tires..........
http://prismphotos.com/gallery/showp...=16160&cat=452
Old 04-30-2007, 10:06 AM
  #1367
TurboGibbs's Avatar
If you get the *** end down you'll have better weight transfer.
Old 05-01-2007, 09:24 PM
  #1368
what a rush!
moregrip's Avatar
eventually I may go a little lower, but for right now I know there are no driveline vibrations the way it sits so for tuning/break-in purposes I'll call it good
Old 05-04-2007, 07:13 PM
  #1369
what a rush!
moregrip's Avatar
Default tranny cooler
finally got around to mounting the tranny cooler in a way I liked
Old 05-04-2007, 07:44 PM
  #1370
what a rush!
moregrip's Avatar
some of the individual pcs that make up the mount:
holes drilled ready for rivets:
aluminum square stock mounted to the stock cross bar:
upper tranny cooler mount using the Magnuson Radix bracket and a piece of aluminum flat bar:
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
