Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1643
Originally Posted by Richard@WCCH
Great job Grip! I can't recall seeing H/E's installed in such a way, but it looks like packaging will work very nicely
Smart looking setup.
Richard
Richard
#1644
Originally Posted by whitt1
Drivers side inlet would be correct.I like the parallel setup it doubles the actual cooling capacity,but I would go with a on/off switch for the fans so you can run them with the engine switched off between runs at the track. Running them in traffic would be a waste.I also would not run antifreeze just water and water wetter,I doubt freezing is a concern in southern Cal.
Your heat exchangers are in series on the airflow side, so you need to be in series on the water side also for maximum efficiency. The front exchanger will receive cooler ambient temperature air while the rear exchanger will (for the most part) see the warmer air from the front exchanger. Run your hot water into the rear exchanger first, then into the cooler front exchanger. This assumes that your pump has sufficient pressure to provide full flow in series operation. Series flow will reduce your piping cross sectional area by 50% compared to parallel flow, so series is more restrictive and requires a good pump with sufficient "head" (pressure) to overcome the reduction in cross sectional area.
The quality and workmanship of your project continue to amaze me. Everything is first class. Keep up the good work!
Yogi
#1647
Originally Posted by Yogi Bear
While freezing temps won't be a problem, corrosion will. Using only a water wetter will not provide any corrosion protection. Use some green antifreeze to get the corrosion protection.
Yogi
Yogi
seems like more people like the idea of running them in series over running them in parallel. The Magnuson I/C pump has plenty of power, that thing is a beast I was running the dual H/E's before with no problems at all. I think these e-fans are going to make a nice difference in traffic, but more importantly in the staging lanes Those little buggers flow 400cfm each @ 4 amps, they had the best cfm to amp draw rating when I was shopping for them.
#1648
Originally Posted by 2005SSR6Speed
Looks great all mounted up, very nice packaging!!!
Originally Posted by 2004Denali
Grippy,
Can you post up a picture of your Evens water pump.
Thanks
Mark
Thanks
Mark
anything
#1649
Originally Posted by moregrip
Yes, I'll snap one today while it's not covered up by
anything
anything
Mark
#1650
Thanks, Rick asked me if I wanted to go with the Evens cooling system or an Electric water pump.
Mark
Mark
