Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1801
Originally Posted by moregrip
I had to measure all the bolts and order them individually
#1802
Originally Posted by Runwhatchabrung
maybe you might be able to help. I had someone pull my motor and trans and was supposed to get work done yada yada well needless to say they fell of the face of the earth with my parts and im left to buy new **** and try to get it all back together. By any freak chance yo wouldnt happen to have a list of some sort of the acessories bolt sizes and quantities do you?
#1803
do you have a Magnacharger Radix setup?
#1809
I started out today like I do most "parts hunting" days not expecting a whole lot......LOL............wouldn't you know it, NAPA is good for something every once in a while
First good find of the day was this pre-formed coolant hose to run from rear H/E to front H/E:
as you can see it worked out perfectly(just need to remember to write the part# down)
#1810
second good find of the day was the correct length 8-Rib Serpentine belt(first one was too short) without having to special order it I was completely blown away on this one, it's not a normal stocking #, they just happen to have one in stock
****, I'll take a win/win everytime, thank you sir can I have another!
here are some good angles so you can FINALLY see what a Magnuson Radix 8 Rib drive pulley arrangement looks like:
glad to finally wrap this project up
Good news is, if you want to run the same setup I have all the info/part #'s you'll need to make it work without having to trial and error it, or piece it together like I did.
