Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1821
Originally Posted by 2004SSS
question grip, how do you pull the iw crank pulley if you need to? and two this is a general question but can you lock the crank in place by locking the converter manually with hpt to remove the crank bolt without having the engine turnover?
it would look something like this:
I have a kent-moore flywheel holding tool to keep the crank from turning.
#1822
last pics of the day,
after some re-arranging, looks like I figured out how to go about mounting the Canton inter-cooler reservoir. couple of things to note: one, it's bigger than it looks, two, it will still fit just fine (albeit with a little more fab work than I originally thought) but it seems to fit the engine bay nicely none-the-less:
#1830
the kent moore tool is that the one that you put in place of the starter? i just want something where i dont have to remove that. just wondering if that idea would work?
