Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1852
Originally Posted by BlownChevy
Oh, scratch that idea. If the temp ranger were lower it would be interesting to try it in the intercooler system. However like water wetter, the temp range is too high to be effective.
#1855
Come on Devon, you know better then to post without pics we are spoiled
yeah wheres the damn pics.... you did this on purpose.... this thread should be deleted
#1856
LS1Tech Sponsor
We run Evans coolant on wet sleeve blocks to help with air pockets. Tried it on stock blocks and it never worked.We had to pull timing due to KR from the higher heat.
Here is the Rad we ran in our 408ci/S85mm truck. It is a early 90's truck style radiator from Jegs.2 core aluminum. It's huge and this truck would not get over 185 degree's in 100 degree heat sitting in traffic(probly be lower if we had better fans).After a 3 gear WOT pull temps would climb to the 180's at most.
Evans has it's place but I wouldn't run it in a truck setup like the one's listed.
#1857
Sorry for Hi-jacking your thread Devin.
Mark
#1858
been thinking about a break-in schedule for the engine, as of today I think it's going to look like this:
0-100miles 30wt petroleum
100-500miles 30wt petroleum
500-2500miles 15w-40 petroleum
normal intervals after 2500 miles will be a blend of synthetic motor oil
something like 4 qts of 10w40 2 qts of 20w-50 or
5 qts of 10w40, 1 qt of 20w-50
#1859
