Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 09-24-2007, 06:28 PM
  #1881
Resident Retard
BlackGMC's Avatar
Originally Posted by moregrip
If my GF saw how you organized all that oil and stuff, she would want to marry you, cause I am way to messy to do something like that!!
BTW, progress is looking great!!
Old 09-24-2007, 07:07 PM
  #1882
Bill Reid's Avatar
...whats the deal with that longer one? anyone know why its that length?
grippy,
blown3qtr's 4L80E rebuild thread is a great source of info... post #5 in his thread briefly discusses what the longer cooler adaptor feeds into (in the aft port).
Bill
https://www.performancetrucks.net/fo...d.php?t=396429
Old 09-24-2007, 07:20 PM
  #1883
what a rush!
moregrip's Avatar
Originally Posted by Bill Reid
grippy,
Bill
very good Bill, thanks, so it might not be a good idea to switch to a shallow fitting that doesn't seat into the aft port?
Old 09-24-2007, 07:49 PM
  #1884
I AM A MOTHERF*CKER
TurboBerserker's Avatar
started working on the transmission cooler lines today or better yet the routing of them. I'd like to run from the tranny, to the radiator cooler, to the external cooler, back to the tranny.
That's what I did. Works great!
Old 09-24-2007, 07:55 PM
  #1885
Bill Reid's Avatar
... not sure bro... maybe JamesB or Vince from FLT can chime in... looks like a support of some kind. I am curious as well. I had planned on modifying the existing longer adaptor by machining/welding -6AN adaptor to it.
Bill
  #1886
what a rush!
moregrip's Avatar
what exactly did you do Erik?
Old 09-24-2007, 07:56 PM
  #1887
what a rush!
moregrip's Avatar
Bill
yeah, I'd like some expert insight on this one
Old 09-24-2007, 09:52 PM
  #1888
FormerVendor
Richard@WCCH's Avatar
Dang Grip..........all's you need is a cash register on the corner of the table and you'd be a bonified auto parts store.
Are you going to route the trans cooler lines along the inside or outside the frame rail?
Richard
Old 09-24-2007, 09:55 PM
  #1889
FormerVendor
leftcoast32's Avatar
I ran my cooler the same way you are looking at doing. I purchased a line that was cut and had -6an fittings welded to it so I could just make a set of high pressure lines real easy. Use all the factory hard lines and just cut and weld the return line from the radiator cooler to your aux cooler.
You can see in the picture below that the hard line coming out of the radiator was cut and welded to allow the cooler to be added in-line.
Old 09-24-2007, 10:16 PM
  #1890
what a rush!
moregrip's Avatar
that looks like a sweet setup, thanks for the heads up bro
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
