Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 09-24-2007, 10:18 PM
  #1891
what a rush!
moregrip's Avatar
Originally Posted by Richard@WCCH
Dang Grip..........all's you need is a cash register on the corner of the table and you'd be a bonified auto parts store.
Are you going to route the trans cooler lines along the inside or outside the frame rail?
Richard
lol, I'm going to use as much of the stock tubing as I can to keep costs down
Old 09-24-2007, 10:53 PM
  #1892
I AM A MOTHERF*CKER
TurboBerserker's Avatar
This is what I did Grip. Except my braided lines are all black and my cooler has a fan lol
Oh I didn't weld the fittings on -- I used the same method as for the fuel line conversion (hard line to AN fittings)
Originally Posted by 2005SSR6Speed
I ran my cooler the same way you are looking at doing. I purchased a line that was cut and had -6an fittings welded to it so I could just make a set of high pressure lines real easy. Use all the factory hard lines and just cut and weld the return line from the radiator cooler to your aux cooler.
You can see in the picture below that the hard line coming out of the radiator was cut and welded to allow the cooler to be added in-line.
Old 09-25-2007, 09:10 AM
  #1893
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The longer fitting supplies fluid to the rear planetary. Here is my -6 that I modified so I could run all stainless lines and AN fittings.
Stocker on the right
I did this per Vince's recommendation, I have a little over 1K on the trans now with no shavings in the pan and it shifts fine, so far so good.
Old 09-25-2007, 11:36 AM
  #1894
rpav's Avatar
Originally Posted by moregrip
damn, it's like christmas around here today
new 200amp alternator showed up today, 105amps at idle
does the dealer carry this? is this the AD-244-A200 or HD200?
Old 09-25-2007, 04:31 PM
  #1895
what a rush!
moregrip's Avatar
did you turn down a bulkhead fitting?
Old 09-25-2007, 04:32 PM
  #1896
what a rush!
moregrip's Avatar
that sir is an ebay special
Old 09-25-2007, 05:00 PM
  #1897
1slow01Z71's Avatar
If I remember right it was a -6 to 14x1.5mm then was cut down to match the factory thread pitch etc. The fitting was like .01 larger then the factory so it was a bit tight screwing it to the casing but I dont think it will be a big deal since its never going to come out and if it does Ill retap the hole while the guts of the trans are out of it. I got a piece of aluminum tubing welded to it before the threads were cut. So yes it is a bulkhead fitting in a long round about way
Old 09-25-2007, 05:29 PM
  #1898
laynlow77's Avatar
do you know what the stock sized inputs into the radiator are? im going to add a cooler as well, and id like to not cut any of the factory lines.
Old 09-25-2007, 05:32 PM
  #1899
1slow01Z71's Avatar
IMO bypass the radiator all together, get a cooler with an external bypass for when its cold it will still get up to operating temp then once it heats up it will start cooling it. The fewer the connections the less chance of a leak and at this point Im all about low maintenance.
If you insist upon going through the radiator I would use tube unions to splice into the hard line, I would want to mess with screwing fittings into plastic, the end tanks of the stock radiator are very flimsy.
Old 09-25-2007, 05:48 PM
  #1900
what a rush!
moregrip's Avatar
new box showed up today:
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
