Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 09-26-2007, 03:15 AM
  #1901
Where's the Beef?
viciousknid's Avatar
Come On Man. Put the camera down and pick up a wrench. Then pick up the camera again cuz i wana see this thing moving.
Old 09-26-2007, 08:01 AM
  #1902
BigCountryx's Avatar
Originally Posted by moregrip
lol, I'm going to use as much of the stock tubing as I can to keep costs down
That's some funny **** right there
Old 09-26-2007, 10:01 AM
  #1903
custom 68's Avatar
I agree
Old 09-26-2007, 03:32 PM
  #1904
what a rush!
moregrip's Avatar
I was trying to figure out how to mount the Canton intercooler tank yesterday, spent the better part of the day modifying a factory auxiliary mounted battery bracket so the tank fits with no interference with the hood while maintaining full access to the drain valve and A/C connection........ rest assured, there is plenty of work being done; although I do appreciate your excitement
I think there's a good lesson to be learned here though.......mainly that things take longer than you anticipate.
Old 09-26-2007, 03:45 PM
  #1905
rpav's Avatar
put together:
insert into space between damper flange and crank snout:
insert machined washer
secure with 180mm bolt
is this damper the standard or 10% overdrive?
thanks
Old 09-26-2007, 05:35 PM
  #1906
what a rush!
moregrip's Avatar
thanks
it's 8" diameter vs the stock 7.5"
Old 09-30-2007, 12:55 PM
  #1907
what a rush!
moregrip's Avatar
dexcool really seems to leave a lot of deposits in the cooling system, everywhere, the ID of the rubber hoses, overflow tanks, inside the radiator, pretty-much anywhere it flows. So far I have replaced everything besides the heater core and heater hoses. I will probably run this setup for a few miles and drain/strain the Evans coolant, then put it back in or replace it all-together........
makes me not want to put it into the intercooler system.....hmm
Old 09-30-2007, 01:03 PM
  #1908
Stoichiometric's Avatar
If you are not worried about freeze protection than run distilled water/water wetter for the intercooler.
Old 09-30-2007, 01:05 PM
  #1909
what a rush!
moregrip's Avatar
thats what I was running before with good results......
Old 09-30-2007, 01:08 PM
  #1910
what a rush!
moregrip's Avatar
anyone run RMI-25 before?
http://arizonagn.net/how_to.htm
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
