Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 03-02-2006, 05:54 AM
  #191
10 Second Truck Club
CurtD's Avatar
Man that's some good work...run them over the axle, you can get them closer to the body.
Old 03-02-2006, 06:11 AM
  #192
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I would dump it after the rear axle if it were me and didnt want side exit after the tire. I personally like the dual tips exiting behind the rear wheel but you bring up a good point on the rubber thing but IMO is the best option since oyu dont like dumps.
Old 03-02-2006, 12:27 PM
  #193
what a rush!
moregrip's Avatar
turned down tips at the bumper and dumps(turned down tips somewhere under the body) are different IMO. Just making sure we are on the same page here Yes, I'm not a fan of dumps, but a turned down tip at the bumper is a consideration. Or even dual (straight exit) out the back evenly spaced, or duals offest to one side out the back( ala XLR8NSS). I will run these ideas bye oxidizr (and then some) as he has all the technical knowledge to evaluate the merits of one system design over another. Remember, the main goal is to have a "Zero Loss" exhaust system. Hence the reason for things like the "new" high flow metallic cats, x-pipe, even to the placement of each component.
Oh Yeah: if you look closely the wheels/tires are stacked up in the garage
Old 03-02-2006, 12:30 PM
  #194
what a rush!
moregrip's Avatar
Thanks Curt, coming from you, that's quite a compliment
Old 03-03-2006, 05:47 PM
  #195
what a rush!
moregrip's Avatar
more good news: I conducted the acid test this morning and ran WOT at the top of 3rd gear( approx 65mph ) anyway 12.2-12.5-1 was the AFR. Just about perfect, I'll be damned if it's not running better than ever.
So was I running Rich before the exhaust?
Maybe, but the O2 sensors looked to be in great shape when we took them out.........funny **** really, but I'll take a win win any day of the week
Old 03-03-2006, 06:13 PM
  #196
1slow01Z71's Avatar
Speeding on a public road
Yeah dumps and turned down behind the bumer are different. If you use mandrel bends for the big angle change to turn them down then I would do that and it wont really hurt performance look good and use the existing tips
Old 03-03-2006, 06:24 PM
  #197
Allgonoshow's Avatar
I'm curious why Richard didn't choose a single muffler with dual in/out with an
internal x, "Tru-X core" design
http://www.magnaflow.com/02product/s...ne=main&id=625
It's much simpler, less fabrication and would be less expensive to duplicate.
Space constrants? or maybe no 3" in tru x ?
I've built several systems similiar to your set up and used one x-body muffler.
Nice stuff, no matter
Old 03-03-2006, 08:03 PM
  #198
what a rush!
moregrip's Avatar
I was going 65 in a 65. Freeway
Old 03-03-2006, 08:06 PM
  #199
what a rush!
moregrip's Avatar
Prettymuch. we had to fit everything between the header collector and the side exit point. Using the mufflers we did, we still had to cut the ends off one side and weld them up to the transition pipes. Also, he wanted to get the x-pipe as close to the header collectors as possible because the farther it is moved away the less benefit is realized. Yes, he went to alot of extra work for the little details.
Old 03-03-2006, 08:10 PM
  #200
James B.'s Avatar
Turndowns before the rear bumper is EXACTLY what I am working on. I've got one side done so far. I wanted it tucked away, no bling, invisible... quiet... STEALTH.
It came out as I had hoped. I did a bologne snub cut similar to factory but deeper.
I don't see many people going to turndowns tucked and dumped under the bumper. I think it looks good and it's very functional. I'm anxious to see how you do yours. (BTW, those are 14x4" round 3"in/out Magnaflow cans in the back working as resonators.)
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
