Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2101
had duty yesterday, a few things showed up while I was away:
first I figured I'd take a few pics of the engine pre-luber so you guys can get an idea of how it works:
took a picture of it next to a gallon of coolant to get an idea of its size:
various fittings for different engines:
hand pump and 6.0L fitting installed:
close-up of valve and 6.oL fitting:
instructions:
oil gallery location used:
instructions:
#2107
LS1 Tech Veteran
You're good to go as is . . . so go as is!
BTW, thanks for the info on the pre-luber. By injecting the oil at the front oil galley, the oil passes through the filter before being fed upward to the cam journals. It's also the easiest place to get to.
Steve
Steve
