Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2121
as long as the above routing is correct adding the larger tranny cooler turned out MUCH better than I expected.
Didn't need any aftermarket lines, just 2 inverted flare to -6AN adapters, 2 -6AN tubing nuts/collars, and one 90deg -6AN fitting. Made two bends with a handheld bender (one 25deg inlet side, one 90deg outlet side); next cut off the factory ends; then flared them to 37deg, done, call it good. Turned out super clean and here's what I did:
view from the front:
#2129
that said, I am getting ready to short order a few steps in the interest of time so I can enjoy the truck for a few months before I deploy
