Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 11-10-2007, 10:57 AM
  #2131
what a rush!
moregrip's Avatar
Originally Posted by Bill Reid
How long is the deployment?
Bill
6-9 months
Old 11-10-2007, 06:19 PM
  #2132
GFYS and STFU
Spoolin's Avatar
Looks awesome!! Truly a thing a beauty Grippy. I don't care if that thing never runs that is a thing of beauty and the detail is incredible.
Old 11-10-2007, 10:50 PM
  #2133
what a rush!
moregrip's Avatar
thanks bro.
doing my best to keep it real
Old 11-12-2007, 06:07 PM
  #2134
what a rush!
moregrip's Avatar
mocked up my braided lines today, I used the Teflon braided lines because I have heard of the rubber variety deteriorating over time and even smelling of fuel once compromised. They aren't the prettiest setup but if I choose to leave well enough alone they will stand the test of time. If you remember I omitted the Magnacharger fuel manifold in favor of a split Y arrangement and kept all my feed lines with no greater than 45deg turns in an effort to maximize fuel supply; still keeping the balance tube up front. The -4 lines you see in the pic are vacuum and fuel pressure respectively:
drivers side:
passenger side:
Old 11-12-2007, 07:00 PM
  #2135
PSM
PSM's Avatar
Truly gorgeous.
Old 11-12-2007, 07:27 PM
  #2136
Stoichiometric's Avatar
Looks good Grippy, I like the Y fitting rather than the 'block'. I'm sure it will help even the flow between the rails and have less resistance.
Are you going to hook up the big rear PCV nipple on the inlet?
Old 11-12-2007, 08:28 PM
  #2137
what a rush!
moregrip's Avatar
on the inlet of the J-Tube?
Old 11-12-2007, 08:30 PM
  #2138
Yeah on the back of the J tube. Are you going to run a PCV or vent to atmoshpere?
Old 11-12-2007, 08:34 PM
  #2139
what a rush!
moregrip's Avatar
well, pcv but without the pcv,lol, know what I mean?
Old 11-12-2007, 08:38 PM
  #2140
Yup, I know what you mean. If you are going to leave the nipple on the inlet of the J tube and the little 1/8th" nipple on the lower manifold capped, change the caps to rubber. I left some vinyl caps on the nipples I didn't need to use and they dry out and crack.
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
