Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2181
Sorry brother, yes, taking each pin out carefully, heat shrinking from the outer ends in toward the central bundle. That's where having someone around who's done it a few times helps, who has already learned how to release the pins on most connectors. There are always a few that need to be figured out though.
#2182
#2185
intake tube
well, finished the intake tube today; it took several mock-ups before I decided on the final configuration. Had to cut the two flex fittings evenly on both sides to get the right fit and symmetry. Here are the pics after the two angled pcs and two flex pcs were glued together:
couple of mock up pics, no MAF, to determine correct clocking:
once clamped to the MAF, pcs fit like a glove:
final assembly:
final assembly:
#2186
Looks great, sorry I wasnt around to help this weekend. I was in Phoenix, AZ pulling an LS2 that had an oil starvation issue and lost the 5 and 6 rod bearing. I am dropping it off for Darton MID Wet Sleeves and then it will be finished as a Forged 427 with 122HH on 10 psi of boost for now. Just give me a yell when you are ready to finish up on the harness.
#2187
thanks Joe, I thought we said this Saturday on the phone?
U/W this week, I'll catch up next weekend, the last few odds and ends should come in this week(fingers crossed)
Holty,
parts list:
2 rubber 4", 22degree elbows
2 rubber 4" hump hoses (7/8" cut from each end with razor blade, electric palm sanded to perfection 40grit)
2 aluminum intake tubes (2" long 4" diameter) used as back-plate to glue the hump hoses and 22deg hoses together; 1" either side)
1 4" to 3.75" reducing sleeve for a tight fit on the 90mm TB (trimmed about 1/4" off the inner sleeve so it didn't hang past the edge of the TB flange; not necessary but a nice touch)
4 4" hose clamps of your choice
1 tube of loctite super glue professional (this stuff is ridiculous, I glued two rubber hoses together as a tester, put one end in the vise and grabbed the other end with channelocks; the rubber started tearing mid tube with the joint showing no signs of separating, not in the least bit, doh!)
your measurements might be +/- a few 16th's of and inch so make sure you measure everything out but this should get you in the ballpark
Holty,
parts list:
#2189
no problem bro, if you look in the first two pics closely you'll see the gap(where the MAF goes) on the inner edge is smaller than the outer edge, so the 2 22 degree angles aren't quite enough to get it perfect; reason I used the two hump hoses, just an FYI
plus it gives the intake some wiggle room when the engine moves around
#2190
Notorious BIG
