Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2552
Adkoonerstrator
WOW!!!, you progressed pretty rapidly(for you ) lately. Big congrats from me on getting it fired up and starting tuning!!!
You don't need to cut grass, didn't you get fake grass a while back?
#2555
looks like I'll be doing an accelerated break-in period (150miles)
odometer reads 34800 even, at 34950 I'll change the oil and go from there WOT style.
#2558
Need More N2O Mod
#2560
3 things I need to change:
1st, I need to hook up the EVAP ****, can't delete one last friggin code via HPTuners.
2nd & 3rd install these:
good shot of both bearings:
I'm going to install the upgraded Magnuson Tensioner and these 90mm double bearing lipped idler pulleys from RR. Really a pretty nice setup. Besides the increased tension the idlers use 2 normal sized bearings sandwiched together via the provided button on the outside of the pulley; provides about 1" of total contact area which should fix any high rpm deflection I may or may not see.
9lbs of boost in the first 2miles isn't a bad thing is it? LOL,
