Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2654
FormerVendor
THANK YOU!!!
1. Richard @ WCCH (Stage II heads, first 90mm J-Tube, ARP hardware, countless hours of advice, and use of your shop!)
2. Rex @ WCCH/Motors by Rex (assembled the forged 365 CID motor)
3. Brian @ Magnuson ( one of the first production 122HH's, countless nick nacks to make the project happen)
4. Richard @ Magnaflow (custom exhaust system, tuning, one of the first sets of truly high flow metallic cats)
5. Joe @ LeftCoast 32 (second set of hands, wiring harness, tuning, custom intake)
6. Tony @ Under Pressure Motorsports (first 122HH truck conversion kit)
7. Art Carr @ California Performance Transmission (awesome 4L80E)
8. Jeph @ formerly of Magnuson (8 rib blower pulleys)
9. ATI (first truck 8 rib setup)
10. and lastly this place!
Thanks to everyone who helped out! Thanks to everyone that tuned in!
It's not 100% done but done enough for now. I'm out of here for a while unfortunately but I should still be online from time to time, especially when we hit liberty ports and I can get some Internet connectivity
see you guys in 6 months!
I'm going to miss this thread..........for a while. Still has so much good info for hot rodder's. We're gonna miss you around here for the next 6 months too. Please stay safe and check in when you can.
Thank you for your service to our country friend. I for one really appreciate your sacrifice.
Richard
#2657
thanks guys
latest:
the wife started the truck for the first time about a 1.5 weeks ago, ran for about 30secs then died. A few days ago she tried again, ran for about 5 secs then died.
The only thing I can think of is the warmer weather is causing this to happen, thoughts?
Obviously, there's not a whole lot I can do from out here, just need some suggestions.
I don't think we nailed the cold start spot on, but we were confident it was good enough to idle and such while I was away.
I'd really like to be able to run the truck longer than a few seconds, keep everything lubricated you know, it will be sitting a long time.
Thanks,
Grippy
latest:
Thanks,
Grippy
#2658
Your plugs are F-O-U-L-E-D.She could probably hold the rpms up a little after start up for like 15sec.Then let it idle down I used to do this when my truck was untuned.
#2659
Have her look at the gauges. Whats fuel pressure, and wideband reading? My guess is the AFR,s are lean, so lean its dieing. From what I have seen overly rich conditions on cold starts the motor will stay running, but die from overly lean conditions. I would look into tuning.
#2660
