Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 01-24-2009, 10:52 AM
  #2781
KySilverado's Avatar
Originally Posted by moregrip
those ports work in conjunction with a new product Magnuson is testing. I'll take some pics of the phenolic spacers when they arrive.
Notice in that pic the size of the intercooler as well, the race 2300 stuff gets the larger intercooler.
I didn't see the inter-cooler size. The height of the intake? Taller?
Assuming from your statement that there will be a common intake port on the blowers and they'll provide a phenolic adapter to match the ports on whatever head design?
Old 01-24-2009, 11:08 AM
  #2782
wastedrubber's Avatar
I'm kinda supercharger retarded, but what's the benefit to the drive cogs instead of the standard style?
Old 01-24-2009, 01:18 PM
  #2783
what a rush!
moregrip's Avatar
Originally Posted by Midnightrider
grippy it looks awesome im extremely jealous. I love the black i cant wait to see the numbers. Soooo should we start a wager on how many tanks of gas you go threw before you go with something different. lol jfwy
your a sweetheart, gee thanks
The good news is that there is not a whole lot of custom anything that needs to happen this time since the injectors are the same brand/type I had before but in a short design, boost level will be about the same(calculated) so the break-in tune loaded will work just fine. I will have to figure out something for an intake tube but that shouldn't be terribly involved. Just install the blower, wire her up, connect the fuel lines, and then "fire in the hole"!.................let's hope
Intake is the same, look inside the intake ports, you can see the intercooler runs the full length of the manifold and is deeper.
I would not interpret what I posted as there being a common intake port, but simply that the lower tub is machined for the phenolic spacer or vise-versa, haven't seen the finished product yet.
no real benefit @ 10lbs of boost as far as I can tell, but certainly a desirable setup when going for the larger boost #'s. My whole reason for going this route was flexibility. This configuration allows me to do whatever I want up to 20+ lbs of boost on my 365 CID 6.0L.
Old 01-24-2009, 01:47 PM
  #2784
wkdivr's Avatar
Now you're gettin me fired up to start working on mine again!!!!!!!
Old 01-24-2009, 01:49 PM
  #2785
To extrapolate a little more for MG. Belt slip. @10 pis the normal v-groove belt would probably be okay. @ 20 it might slip.
Old 01-24-2009, 02:00 PM
  #2786
what a rush!
moregrip's Avatar
yeah buddy!!! go turn the lights on in the garage and get to work
absolutely
Old 01-24-2009, 02:03 PM
  #2787
so that being the case, in the future you have the option to do a cog style for all your pulleys in the front? makes sense, that would pretty much cancel out belt slippage entirely.
Old 01-24-2009, 02:12 PM
  #2788
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
But make for an expensive and noisey setup, if you converted totally to cog therefore you can go 8 rib which isnt any louder then stock but still a pretty penny.
Old 01-24-2009, 02:34 PM
  #2789
what a rush!
moregrip's Avatar
without getting onto the weeds, each belt drive has it own set of benefits, characteristics, and limitations. I'm just going with a setup that I think will work best vs. the least amount effort to install on my current 8 rib setup. This may prove to be sufficient or I may need to go a different route to get everything to play nice
Old 01-24-2009, 04:37 PM
  #2790
zippy's Avatar
Very nice Grippy. That would have been my blower of choice for your truck. I'd like to see it in person someday.
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
