Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#2791
The benefit of the cogs I can see is you can run a much bigger front pulley on the jack shaft to get a lot more surface area for belt contact and reduce slip on the surps to pretty much nothing and then do your stepping up on the cogs with big and little pulleys that WON'T slip.
#2792
so is it on yet??? Or are you gonna look at it for a while and talk about rear springs!
this time around he does not have to build his engine and other stuff thats done....this build should fly
should fly ?
should fly ?
#2795
The cogged belt will make more noise, but it should last quite a while and you'll know if it slips, teeth will come off of it. The rear looks like it is a 1:1 correct?
#2800
yea I am just a bit jealous...ok ALOT.
I would rather wrench than watch football anyway....supersunday in a new way!
I know you wont need help but get an assistant to take abunch of pics.
