Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 02-10-2009, 05:42 PM
  #2891
what a rush!
moregrip's Avatar
staying returnless for now, very much like what I had before
Old 02-11-2009, 02:35 AM
  #2892
SuperchargedSS's Avatar
need MORE!!!!!!! Must...see...more!!!
Old 02-13-2009, 07:59 AM
  #2893
DrX
DrX's Avatar
How do I miss this stuff?? Need to check out the Pojects Gallery more often. Lookin good Grip!
Old 02-14-2009, 06:00 PM
  #2894
what a rush!
moregrip's Avatar
thanks brother!
Update:
Starting the project today I've got everything I need to complete the install minus a TBSS or SSR Evap/Purg Valve and a bracket that's being made.
Currently fabbing mounts for the CTS-V heat exchanger, has taken me a while to figure out a way to mount it I'll be happy with.
Thanks BC for all the assists!
Old 02-14-2009, 06:03 PM
  #2895
GMCtrk's Avatar
Hey, Moregrip,
Did you modify your 4l80e's pump to work with the PI converter? I'm looking at going with the 10.5" 3000 myself with the 80e.
Old 02-14-2009, 06:09 PM
  #2896
what a rush!
moregrip's Avatar
Originally Posted by GMCtrk
Hey, Moregrip,
nope, why, are you running into an issue?
Old 02-14-2009, 06:21 PM
  #2897
what a rush!
moregrip's Avatar
and so she begins.......................again:
Old 02-14-2009, 06:28 PM
  #2898
what a rush!
moregrip's Avatar
I don't have the converter yet, but I was reading PI's installation manual in PDF format and it says that the converter comes with a spring that you install into a valve in the pump. I searched and there was also a couple threads about it here by Bill Reid and KySilverado.
Here's a picture of it courtesy of Bill Reid. It's the red spring and apparently you have to grind down that notch to get the spring to fit over it.
Here's a quote from Vince @ FLT. If I'm reading this correctly Parish ran without the spring mod just fine. If everything works fine without the mod, I'd rather not tear into anything.
Also, I see you have the 2800 stall speed. How do you like it? I've read the 3000 is a lot like stock just driving around normally but is really nice when you get on it.
Thanks
Michael
(just picked this up last night - happy as a tit)
I did not do that step when I put in the shift kit with the stock converter. California Performance Transmission built my current tranny and prior to the build I told them what converter I was running. That's all I can say about it, sorry not much help. Congrats on your new parts!
I haven't had much time to play with the new converter, but so far it seems to drive just fine.
Old 02-14-2009, 06:50 PM
  #2899
supersub's Avatar
here is a few of mine to help get you started....
Old 02-14-2009, 07:01 PM
  #2900
what a rush!
moregrip's Avatar
thanks bro, going with something very close to that
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
