Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 05-18-2011, 11:44 PM
  #3111
GFYS and STFU
Spoolin's Avatar
Originally Posted by moregrip
why, you scared?
Come help me finish up my truck and maybe you'll find out!!
Old 07-17-2011, 11:23 AM
  #3112
what a rush!
moregrip's Avatar
I think the main reason I haven't adressed the stance is I go back in forth between how much I should drop it........there are a few "kit" options in McGaughys and DJM starting with a 5/3 in both and a 8/6 in the DJM only. Lastly there is the Ride Tech kit that's at least 8/6......
all of these at various price levels of course
As most of you know I've been running a 1500 leaf pack and velvet ride shackles for most of it's life and that alone brought the rear down about 1 1/2" or so.......I think there's a 1" difference front to rear as it sits now...
Other option:
Rear; I have a set of 1500 Hotchkis 4" lowering leaf springs and belltech 3" drop shackes that I think will work quite well out back....although a more non standard approach I like the idea of 7" f rear drop without having to run a flip kit.
Front; if I go with the Hotchkis/Belltech option for the rear.....I'd need to run either the DJM front setup or the Ride Tech......for around 6" total drop
as for carrier bearing relocation there are no real sano setups out there in kit form, although I like the way Ride Tech does there's best
thoughts?
Old 07-18-2011, 06:59 PM
  #3113
what a rush!
moregrip's Avatar
Also, where can I get info on the sportsman s/r tires?
Treadwear?
How they handle?
How they hook?
Or similar tire...........
Old 07-20-2011, 09:25 AM
  #3114
what a rush!
moregrip's Avatar
here are my choices:
Suspension Components :: StrongArms :: 2001-2006 GMC HD Dually - StrongArms System for ShockWaves - RideTech.com - Air Suspension Specialist
DJM Suspension - 2001-2006 CHEVY HD
McGaughy's Classic - Dually, Hummer
Old 07-21-2011, 12:31 PM
  #3115
what a rush!
moregrip's Avatar
Originally Posted by whitt1
Are you going with the Evans coolant?I have found that with the Evans coolant/waterpump combo and 90mm throttle body,I can run as much as 29 degrees of timing with no KR at 100degrees ambient temp.I hope that will be helpfull with your tuning.
bumping this quote for my reference
Old 07-21-2011, 01:34 PM
  #3116
Praise The Lowered
RibeiroBJJ's Avatar
Hey MoreGrip, How much did your ride quality improve with the Velvet Ride shackles..and would you happen to know where to get another set? Or if ever want to sell yours...let me know..I am on a quest to have a VERY low static drop with a Very smooth ride..I was also looking at the Sulastic shackles, but they are pricey as hell...around $350
I would do a flip kit if I were you..Nothing will ride as well as a oem leaf
Old 07-21-2011, 01:44 PM
  #3117
what a rush!
moregrip's Avatar
thanks for the recommendation
the velvet rider shackles are no longer produced (I believe LORD corp made them). As for the ride they made a noticable improvement on ride quality, meaning better, or more cushy.
Here is the original thread:
https://www.performancetrucks.net/fo...-378253/page2/
Old 07-21-2011, 02:07 PM
  #3118
Nuclear Endless's Avatar
From everyone I've talked to about their lowered trucks, theyve been like 4/6 or 4/7, and they say there is no other way to go that low besides a flip kit and notch, it is just much better and a lot less dingy than any other option
Old 07-21-2011, 05:06 PM
  #3119
what a rush!
moregrip's Avatar
thats good info.....I suppose a flip kit wouldn't be terrible and I could keep my velvet ride shackles (which I like).....just hate to see those Hotchkis springs go to waste.....
If I went with the flip kit I think, being a 2500HD, I would end up with more like a 5/7 or 6/8
Old 07-22-2011, 07:52 AM
  #3120
GFYS and STFU
Spoolin's Avatar
I really suck at suspension advice Grippy but if it helps, PM Dezert1500. He knows more than a thing or two about how to lower a truck and not only keep the ride but improve the comfort. I've ridden in his slammed truck and it rode better than some high end luxury cars i've been in.
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
