Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#313
How is that? You just posted two different readings.
You have a 5* pinion angle. Actually yours should be -5* like you stated above.
Looks like GM gave you too much of a negative pinion angle.
At least that's what it seems after reading my link.
Your HP is low anyways! It needs to like a 0* for that weak engine.
It stated that (assuming this is the kind of power you will be making) when producing 500-650HP, you should only have 3-1/2 to 4-1/2 * of pinion angle.
I'm assuming there talking negative pinion. Meaning nose of diff dipping more towards the ground.
What do you think?
Jim
What do you think?
Jim
#314
What do you think?
Jim
What do you think?
Jim
I will unload my Caltracs and see if that changes anything, probably will.
#315
Originally Posted by moregrip
I understand it a little differently, mainly that its the relationship between the differential angle and driveshaft angle thats critical(i.e. pinion angle). Are you saying in addition to being between 3.5* and 4.5* the diff should be pointed down?
I bet your diff angles change after doing so.
Yes, your diff should be pointing downward. When you accelerate, the diff will be wanting to twist upwards. You really don't want it to go much past 0* if any at all under acceleration.
That's what I got out of my link that I posted above.
Jim
#317
That's why the Caltracs work. They take the twisting force of the diff to raise up the front and plant the trear tires into the ground!
Just felt like saying that!
Jim
Jim
#318
mine are coming off, tired of all the freakin noise, going to a ladder bar setup similar to what the Lightning guys use
The Caltrac Pics post has it in there about eliminating the noise.
Just thought I let you know before you ditched them.
What exactly are the Lightning guys using?
Any pics of it? Sounds like totally fabbed components.
Jim
#319
Place a rubber hose over the pin that rests on top of the leaf springs. The noise goes away so I hear.
Jim
Jim
#320
for my setup the rubber tube would help but wouldn't eliminate the squeeking I get from the plates rubbing against the side of the leaf springs
Too bad a grease sert couldn't be added at the eye.
Sounds like a possible problem.
Jim
