Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 11-02-2006, 12:32 AM
  #321
what a rush!
moregrip's Avatar
Originally Posted by CHEVY6000VHO
Looks like I will be placing some marine grease there before assembly. I wonder if aerosol lithum grease will get in there with them installed?
Too bad a grease sert couldn't be added at the eye.
Sounds like a possible problem.
Jim
aerosal lithium does zero for me
The problem is less noticable on a 1500 leaf pack because there are less leaves at that point where the caltrac side plates pivot on.
Old 11-02-2006, 10:43 AM
  #322
what a rush!
moregrip's Avatar
anyone else have any insight on this or do I need to go to a driveline shop?
Old 11-02-2006, 02:08 PM
  #323
what a rush!
moregrip's Avatar
for the record and before I start messing with ****, here are all my ride height measurements(Caltracs still loaded)
driver front(38 5/16)
driver rear(41 8/16)
pass front(38 11/16)
pass rear(41 13/16)
Old 11-02-2006, 02:41 PM
  #324
what a rush!
moregrip's Avatar
drivers rear/unloaded caltracs (41 4/16)
pass rear/unloaded caltracs (41 10/16)
front measurements = no change
Old 11-02-2006, 03:36 PM
  #325
Adkoonerstrator
XLR8NSS's Avatar
4/16....8/16....10/16?
Old 11-02-2006, 03:44 PM
  #326
what a rush!
moregrip's Avatar
now here's an interesting find, with the caltrac's unloaded ALL angles changed as follows:
...............................caltracs........... .............unloaded
diff angle.....................93*..................... ..........92*
rear d/s angle...............98*........................... ....96*
front d/s angle..............95*............................ ...93*
trans angle...................95*....................... ........93.5*
pinion angle w/caltracs loaded -5* (diff 3* up)
pinion angle w/caltracs unloaded -4* (diff 2* up)
is my math correct here folks?
Old 11-02-2006, 04:46 PM
  #327
Sounds right. I figured you would have had the answers by now......
I think I will keep my o.e. hangers and just shim my axle to a pinion angle of -3 or -4. Lets just hope the 2* shims that I have will allow these angles.
Caltracs will be installed tomarrow.
Jim
Old 11-02-2006, 05:34 PM
  #328
Mort's Avatar
Cool
That looks correct to me.
What reference surface are you using to measure your pinion yoke face? In theory you are supposed to pull the axle and measure on the surfaces that the u-joint mounts to. If you are happy that your diff angles are accurate then those calculations look good to me.
Old 11-02-2006, 05:54 PM
  #329
what a rush!
moregrip's Avatar
I used the the flat of the U-joint outer bearing surface
If I'm off, it's not by much
Old 11-02-2006, 05:55 PM
  #330
what a rush!
moregrip's Avatar
got the bushings out of one 1500 leaf pack, starting on the next
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
