Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#321
Originally Posted by CHEVY6000VHO
Looks like I will be placing some marine grease there before assembly. I wonder if aerosol lithum grease will get in there with them installed?
Too bad a grease sert couldn't be added at the eye.
Sounds like a possible problem.
Jim
Jim
The problem is less noticable on a 1500 leaf pack because there are less leaves at that point where the caltrac side plates pivot on.
#326
now here's an interesting find, with the caltrac's unloaded ALL angles changed as follows:
...............................caltracs........... .............unloaded
diff angle.....................93*..................... ..........92*
rear d/s angle...............98*........................... ....96*
front d/s angle..............95*............................ ...93*
trans angle...................95*....................... ........93.5*
pinion angle w/caltracs loaded -5* (diff 3* up)
pinion angle w/caltracs unloaded -4* (diff 2* up)
is my math correct here folks?
#327
Sounds right. I figured you would have had the answers by now......
I think I will keep my o.e. hangers and just shim my axle to a pinion angle of -3 or -4. Lets just hope the 2* shims that I have will allow these angles.
Caltracs will be installed tomarrow.
Jim
Jim
#328
What reference surface are you using to measure your pinion yoke face? In theory you are supposed to pull the axle and measure on the surfaces that the u-joint mounts to. If you are happy that your diff angles are accurate then those calculations look good to me.
#329
Originally Posted by Mort
That looks correct to me.
If I'm off, it's not by much
