Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 12-08-2006, 08:25 PM
  #571
laynlow77's Avatar
looks like its coming along nicely!
Old 12-08-2006, 08:32 PM
  #572
the day is upon us
Old 12-08-2006, 09:10 PM
  #573
Bill Reid's Avatar
Originally Posted by moregrip
I'd like some, but I don't know a machine shop that does solid work that can turn my block around on short notice
I'd maybe talk to Richard off to the side. If he can supply the slugs... my bet is he probably knows someone who can turn it quickly... with quality. If there is a will there is a way... epecially since you are this far along. And my bet a quality job completed for you would probably net another job or 2 for that machinest... easy. Since yer in there... maybe slip the machinest a few extra bones for a 4" crank... well, since I have your wallet open
Best of luck grippy and thanks for documenting your journey.
Bill
Old 12-08-2006, 10:35 PM
  #574
TurboGibbs's Avatar
If you could live without a balance job on your tight notice a set of forged pistons would be good. Hell, maybe you could get it balanced within a few days. All the block would need is a good hone with torque plates (which is better than the factory does) since the forged pistons usually require .002" or so more tollerance than the stock cast pistons.
On the other hand I have know of people running 9.5 comp and 14lbs boost with meth and 93 octane and staying on top of the tune with stock pistons. The key is a close watch on the tune of course.
Old 12-09-2006, 08:39 PM
  #575
what a rush!
moregrip's Avatar
a little block prep
Old 12-09-2006, 08:48 PM
  #576
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
You use a stone?
You going to put some good pistons in it or roll with what ya got?
What are you going/did to use to clean the cylinders and rotating assembly? Im not having very good luck getting the rotating assembly clean with carburetor cleaner, everytime I rotate it over there is still alittle black residue on the cylinders.
Old 12-09-2006, 08:53 PM
  #577
1slow01Z71's Avatar
An observation I have made form your pictures. It seems GM is really trying to standardize parts. Like you LS2 cam gear, the bolts for your valley cover are LS6 bolts, the LS2 rods and I would be willing to bet your pistons are the same they put in the LS2s. Guess it cuts costs to use the same rods and pistons in all the 4" bore engines even if the rods are a little more beefy(maybe expensive?). Wonder if your motor came with the LS6 oil pump?
Old 12-09-2006, 09:31 PM
  #578
what a rush!
moregrip's Avatar
You use a stone?
WD40 and lacquer thinner
Old 12-09-2006, 10:00 PM
  #579
what a rush!
moregrip's Avatar
upon further review it does appear the stock balancer was spinning on the crank
Old 12-09-2006, 10:03 PM
  #580
what a rush!
moregrip's Avatar
block is pretty-much good to go, you guys see anything I missed?
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
