Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 12-12-2006, 06:05 PM
  #661
blownerator
BlownChevy's Avatar
Originally Posted by nightrunner
now that makes more sense since the ls2 was made after the lq4
whoda thunk it
Old 12-12-2006, 06:09 PM
  #662
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The first time they showed up in a motor was in the LQ9, then carried over into the LS2/LQ4 motors so the LS2s and LQ4s use LQ9 rods
Old 12-12-2006, 06:22 PM
  #663
what a rush!
moregrip's Avatar
Originally Posted by BlownChevy
You ever consider that the LS2 uses LQ4 rods?
LS2/LQ9 rods where originally different than LQ4 rods, so no, I guess you could say the LQ4 uses LQ9 rods if you wanted to. Looks like they are all the same in 05 and up
Old 12-12-2006, 06:25 PM
  #664
what a rush!
moregrip's Avatar
all out:
tried to get a good angle on the cylinders walls:
Old 12-12-2006, 07:05 PM
  #665
This could be a new manual. Excellent work.
Old 12-12-2006, 08:03 PM
  #666
what a rush!
moregrip's Avatar
latest:
main bearing cap removal tool in action:
caps removed:
crank removed:
I won't be around for a few days but I'll be sure to take plenty of pics
Old 12-12-2006, 08:04 PM
  #667
1slow01Z71's Avatar
Grip a tid bit of advice, use blue loc-tite on EVERYTHING in the engine. I tq'ed everything to spec on my engine and some of the bolts were looser then what they should when I disassembled it. Also, when putting the lifters in put them in the lifter tray then in the lifter bore, for some reason the people on tech think you should put them in the lifter bore then put the tray on. The lifter tray retainer bolts are 108 in-lbs. Also pour oil in both holes that go to the oil filter before putting the pan back on so it will help prime the motor even further. Make sure to use a rod bolt stretch gauge instead of a tq rating it is far more accurate.
Im sure you know most of this just wanted to share a bit fo my the knowledge I have attained in my builds and hopefully make things go a bit smoother for you.
Old 12-12-2006, 08:06 PM
  #668
1slow01Z71's Avatar
Richard said ya'll were going to have a fun shin-dig up there at his place, good luck and it should be one hell of a setup once done.
Old 12-12-2006, 08:09 PM
  #669
what a rush!
moregrip's Avatar
Thanks bro, I'll keep those tips in mind. I'll have a couple of pros helping me out with the long block assembly so I'm sure everything will go smoothly
Old 12-12-2006, 08:13 PM
  #670
Destroyer of Transmissions
1SlowHoe's Avatar
all out:
You spent all that time cleaning the pistons and some *** clown comes along and writes all over them. .....................
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
