Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 12-15-2006, 12:19 AM
  #721
Bill Reid's Avatar
Originally Posted by moregrip
Bill, sup brother!
We will be degreeing the cam tomorrow. Ed Curtis has already address excessive cylinder pressure with this new bumpstick, it will handle 10-1 CR and boost no problemo
Cam specs you posted along with the MP122HH...
Keep the awesome pics coming!
Bill
Old 12-15-2006, 08:13 AM
  #722
TurboGibbs's Avatar
My combustion chambers are 73.5cc's, -3cc valve reliefs, .008 in the hole, and as of now stock GM MLS gaskets. .054 is what I've seen typically used for compressed gasket height calculations. These rods are also 6.125
9.3-9.35:1 compression in case you didn't know already.
Old 12-15-2006, 09:33 AM
  #723
zippy's Avatar
That should go pretty well with the low boost numbers. With all the parts you've picked I'm guessing that the 2.8" pulley should net about 10psi@6000rpm. The torque off idle should be rather impressive though.
Old 12-15-2006, 01:24 PM
  #724
what a rush!
moregrip's Avatar
with the 2.8 it will be well over 10lbs of boost
Old 12-15-2006, 01:32 PM
  #725
what a rush!
moregrip's Avatar
latest progress:
Old 12-15-2006, 01:51 PM
  #726
TurboGibbs's Avatar
I think he forgot you have the MP122H.
Old 12-15-2006, 02:07 PM
  #727
High on diesel fumes
thunder550's Avatar
I <3 his shirt
Old 12-15-2006, 02:13 PM
  #728
zippy's Avatar
I remembered about the 122H. I was going from the numbers that the GTO put down. That was a pretty much stock 5.7L with a 2.9" pulley. Between the extra cubes, cam, headers, heads, etc, I'd expect at least a 1-3psi drop in boost over the GTO which would put him in at just over 10psi.
Old 12-15-2006, 02:18 PM
  #729
what a rush!
moregrip's Avatar
only if it was converted to a 1 to 1 rear drive ratio and was running an 8" crank damper
Old 12-15-2006, 02:22 PM
  #730
what a rush!
moregrip's Avatar
measured cam specs @ .050 came out to:
224/238.5 600/586.5 115.875LSA, 3.375 advanced
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
