Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#781
Tin Foil Hat Wearin' Fool
Originally Posted by TurboGibbs
Calm down. A little overkill never hurt anyone if it makes them feel better. But stock bolts SHOULD be fine if installed properly. 90% of the load on the cam gear is shear load which doesn't require as high a quality metal as a rod bolt which is under tensil load.
Lookin good moregrip. Now hurry up!
#782
Cuz I AM a BADMOFO
Originally Posted by XLR8NSS
Enough jabbering.
Grip, is the motor in or what?
#784
Do you not add ARPs for strength? Im just asking why he replaced something that doesnt need it, why do you need a great quality bolt for something that the stocker is more then enough for? Thats why I asked since an engine builder with TONS more experience then me likes them and I am wondering why.
Sorry for getting off target here but just passing along my experiences.
Great build so far Grippy......I think its about time for an update!!!
#785
Hope you guys dont mind if I put my two cents in about the cam bolts,but I have seen A few of the c-5 and zo6 with their cam bolts sheared or loose and these were stock engines.I have built many gen 3 engines and used the stock cam bolts with locktite,but I do now use A quality cam bolt as I do not want this inexpensive upgrade to haunt me. THANKS REX-------
#786
#787
blownerator
ditto on that Rex, we have seen that plenty of times here!
#788
Since the rotating assembly was balanced internally and the crank damper spun to insure a neutral balance I needed to address the flex-plate; dropped the Meziere unit off at the machine shop yesterday, they called back today saying it was perfect! Absolutely perfect , I'll go pick that up later today and then I should have everything I need to put it all back together.
