Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 12-20-2006, 09:54 PM
  #841
Destroyer of Transmissions
1SlowHoe's Avatar
Originally Posted by 8ALTNG
I see a NOS fogger in there...............when did nitrous become part of this build??????
Curious about that as well.
Old 12-20-2006, 09:57 PM
  #842
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Looks like a NOS Y not nozzle.
Old 12-20-2006, 10:08 PM
  #843
203Cree's Avatar
I didn't catch what lower pulley you said you were running, but just FYI and for future reference for those that don't know, this is how to calculate blower RPM....
Lower Dia / Upper Dia = Pulley ratio
Pulley ratio x Engine RPM = Blower RPM
You can plug in any value for engine RPM and it will tell you how fast the blower is spinning at that RPM.
I don't know the max on the 122's, but I know on the old 112's bout the most you could run before you really hit a wall was 16-17k, and even then, you better be intercooled to run it. IAT's were thru the charts at that level.
Old 12-20-2006, 10:30 PM
  #844
Adkoonerstrator
XLR8NSS's Avatar
Originally Posted by BADMOFO
I heard you were groovin' on the new Toyota thread. Did you ever get one, or just a truck that looked like one?
Old 12-21-2006, 01:51 PM
  #845
what a rush!
moregrip's Avatar
quick update:
picked up the drive-shafts from Oceanside Driveline this morning; glad I took them in, they said they were pretty good/close stock but now they are perfect. So that's pretty-much it for all the balance work, I should be good from the crank damper back to the rear-end.
Something I learned about the stock 3/4 ton Dana setup is they can only be timed "one way" so its impossible to assemble them incorrectly or "out of time"
Sidenote: I dont remember if I mentioned it earlier, but look to the LS7 to source a new rear main seal if/when needed. They are not the old two lip going in opposite directions design, the lip on the LS7 seal only goes in one direction which lowers the chance of installing it incorrectly.
Old 12-21-2006, 01:59 PM
  #846
what a rush!
moregrip's Avatar
Originally Posted by Wilde Racing
That dampener looks WAY good.
thanks bro , it does look pretty sick
Old 12-21-2006, 02:02 PM
  #847
what a rush!
moregrip's Avatar
No nitrous bro
thats just a cool -6AN Y fitting; cuts down on the amount of AN fittings needed to split the stock fuel line. I will not be using the standard Magnuson supplied drivers side fuel rail/fuel block for the new setup, switching to a direct feed into the back of each fuel rail via that NOS Y fitting
Old 12-21-2006, 04:08 PM
  #848
what a rush!
moregrip's Avatar
just ordered a couple of $15 bolts M16 x 2.0 x 180mm
Stock damper bolt is approx 100mm long
Replacement bolt for Innovators West damper for a vette application (what I have) 130mm long
What I actually need is a bolt 180mm long! doh! I upgraded to a 12.9 rated bolt and made sure this length bolt would contact all threads in the crank snout. (that was a nice 2 hour journey)
Old 12-21-2006, 04:25 PM
  #849
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Don'tcha just love **** like that?
Welcome to my rear axle install
Old 12-21-2006, 05:50 PM
  #850
Mr. Sandog's Avatar
Originally Posted by moregrip
quick update:
Good choice - Jerry's a great guy and knows his stuff when it comes to driveshafts.
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
