Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old 01-01-2007, 07:20 AM
  #921
FLT
FormerVendor
FLT's Avatar
When is thing going to be done? I had heard of dates much sooner! I guess shooting for sometime in 08 would be a good goal. J/K Looks good and I'm sure you will be happy when it's finally done. Also because you did alot of it yourself you will really appreciate it more. Good luck with the final results Devin. Vince
Old 01-01-2007, 12:40 PM
  #922
How do I change this text
Wilde Racing's Avatar
Wow that looks way good, I agree with Turboberserker. mock up be fore you change anything!
Old 01-01-2007, 06:36 PM
  #923
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Why didnt you paint the mainfold too?
Old 01-01-2007, 07:44 PM
  #924
what a rush!
moregrip's Avatar
well, I've been through a few iterations now, currently it's in a sanded, ready for paint condition........which btw........I really like! wonder if there is a way I could just leave it like this?
Old 01-01-2007, 08:04 PM
  #925
1slow01Z71's Avatar
VHT sells a clear coat that looks really sweet and will "seal" in what ever finish you currently have. Most people that paint their blocks use the clear too.
Regular enamel PN VHT-SP145
Polyurethane enamel PN VHT-SP29
Not sure which one you want to use.
Old 01-01-2007, 08:29 PM
  #926
what a rush!
moregrip's Avatar
new tattered grunge look!
Old 01-01-2007, 09:11 PM
  #927
1slow01Z71's Avatar
How are you keeping the black paint dust from getting on everything. When I painted my block that crap drifted everywhere, it didnt stick but it left a sort of paint "dust" on alot of stuff.
Old 01-03-2007, 01:35 PM
  #928
what a rush!
moregrip's Avatar
common practice is to wet the floor before you paint, you can make a pretty decent paint booth with plastic sheeting, a wet floor, and a home box fan pulling air from inside.
I didn't do any of that, just prepped and painted, came out pretty good the first time so I didn't mess with it........
Old 01-03-2007, 07:18 PM
  #929
what a rush!
moregrip's Avatar
looks like we have a winner!, Crank Damper Issue's are solved now
the problem:
Stock damper bolt is approx 100mm long
Replacement bolt for Innovators West damper for a vette application (what I have) 130mm long; What I actually need is a bolt 180mm long! doh!
stock bolt, 130mm bolt vette guys use with Innovators West Damper, 180mm Bolt needed for Innovators West Damper (truck application)
machined nylon to hold crank keyway in place when bolt is tightened (sandwiched), this is the correct length for vette applications, I'll need a different length for my truck application........
Old 01-03-2007, 07:29 PM
  #930
Bill Reid's Avatar
Originally Posted by moregrip
[B][COLOR=DarkOrange]looks like we have a winner!, Crank Damper Issue's are solved now
Details bro ... get the right length of nylon spacer or what?
Bill
Quick Reply: Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
