Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#951
Most spot putty and Glazing putty have Denatured Alcohol (or the like) in them so they etch them selves into/onto whatever your trying to fill. if you try to sand it before it's totally dry it'll pull up what it was trying to stick to. sounds like what happened to you. if you go to a marine supply store and get a two part glazing putty you can fix the F-up you have now. it still sands real easy and you can paint over it without primer. 100 times better than any bondo or one part glazing putty, it'll never swell or shrink. Hope you get that baby running soon. Now get out there and install sum'N...
#952
#953
Originally Posted by moregrip
maybe I'll try and do that, how much weight are we looking at?
#954
FormerVendor
I'm with TurboGibbs. Put both the engine and trans together on a bench, floor or hanging from the hoist then put the whole assembly in. With the core support out it should make the job far easier on your back!
Not to mention you can more easily check converter/pump engagement and tighten the bellhousing bolts.
Wish I could be there to help
Smooth sailing chief
Richard
Richard
#956
High on diesel fumes
Originally Posted by nice_n_lo_silverado
how difficult is it to reinstall the core support after then transmission and engine are in place?
Grippy - here's another vote for putting the motor and tranny together first then sliding them in together. It will be much easier that way.
#957
I wonder, can you just drop the motor with the maggie on top? I wouldn't do it or recommend it...Wonder if it is doable tho? If it is I bet that would save a lot of time. Supercharger engine and trans all together ready to go?
#958
I'd say no because the engine sits too far under the cowl and the chain and hoist would interfere. The chains need to be as low as possible to clear the cowl and to get the engine set in.
