Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#983
i have soem questions on your 8 rib, why did you go with an innovaters west over an ati damper? and is there some sort of pin on the crank pulley so it wont slip? did you have the other pulley cusotm sized by metco? im curious as to how all the pulley line up. arent some for a vette or f body? did you get the entire waterpump with the 8 rib pulley or did you just put the pulley on the waterepump? im trying to do this as well so i need all the help i can get. thanks.
#984
#985
Originally Posted by negativeswitches
moregrip
do you recall what size thread chasers you used when cleaning out all the tapped holes in the block?
-Erik
-Erik
ARP Head thread chaser:
cleaning out all the threads:
for the rest of the threads to be cleaned:
#986
#987
man youve done your set up right, this thread is so long i missed where you tapped the new holes for the heads. would you mine telling what size bolts you went with? i know it has probably been said but i dont want to go through 65 pages.
#988
