Project Silver Bullet!
Old 11-19-2015 | 01:31 PM
  #31
zblee's Avatar
Got my new deatsch werks 38lb 32D-00-0038-8 injectors in the mail the other day! hopefully getting them installed during thanksgiving week...They should be plug and play physically and they provided all the tuning data via email/excel file. I believe they provide data for a returnless fuel system and the injector data changes as the kpa changes but upon looking at my stock data I think I only need to copy over some of the data they provide (still looking into this)
_Zblee
Old 12-07-2015 | 03:02 PM
  #32
zblee's Avatar
parts are starting to come in! just going through my list and checking it twice, have a few more items to order and some tools. just got word that my heads are finished over at AI and hopefully get those back soon!
i took advantage of btr's black friday sale!
_zblee
Old 12-24-2015 | 04:49 PM
  #33
zblee's Avatar
Headed back to parents early for christmas and started my cam/head swap!
Parts bench
intake off - dirty !
front accessories off and rockers exposed
heads off!
after block was bare decided to change out the motor mounts
driver side was starting to crack
passenger side was destroyed and missing the entire piece of rubber! This was the reason why my headers did not fit properly!
timing cover off
exposing the cam!
pulling out the stock cam
stock vs new AI 224/228 .610/.605 114+2 cam
cam card shows that the grind was extremely close to what it was speced to be , within .5% of the speced duration! spec was 224/228 .610/.605 114+2 - actual final specs are 225.2/229.1 .610/.604 114.3+2.8 . overall overlap is -0.7 so it should i have a noticeable lope . for reference the popular 224R 112 has 0 degrees of overlap so it should be very slightly less lopey than the 224/224 112
New heads! started off as a craigslist find of some 799's that came off of a NBS tahoe with supposedly 80k miles. was left out in the rain so the valves and springs were junk. found a set of used valves on craigslist to replace the stock rusty ones. contacted phil at advanced inductions he was able to help me out. they recommended their 243 cast 226cc port job and had them milled down .03" which then the chambers measured 60cc. With my fel-pro .041 ls1 head gaskets it should bump my static compression to roughly 9.87:1.
updating the stock rockers with the trunnion bearing upgrade
new cam test fitted and in with new cam bolts, cam
gear and retainer plate
_Zblee
Old 12-24-2015 | 04:50 PM
  #34
zblee's Avatar
old crank gear coming off
new gear getting pressed on
everything torqued down including new chain dampener. had to use the trick flow adapter as this block does not have the bolt holes for a dampener. was a tight fit. first installed the adapter , then install the chain / gears. after chain and gears are on then you can press on the dampener.
old oil pump out and new oil pump in - crossing my fingers that i did not pinch the pickup tube o-ring.
new ATI balancer on , front cover back on and torquing down the heads
both heads on !
front accessories going back on
upgrading the rest of the rockers
headers back on and clearance is looking much better with the new mounts haha
as the engine sits right now! measured and ordered pushrods on monday morning. chose 2-day shipping to get it here before xmas. fedex is not holding up on their end I dont think ill get my pushrods until after the weekend! kinda pissed on that part. so it sits like this until i get my pushrods!
so far so good! cant wait to fire it up and drive it!!! this was the first time doing ALL of this - never done this before or even helped anyone before. My haynes book for the truck was probably one of the best investments i made on this swap.
_Zblee
Old 12-24-2015 | 06:14 PM
  #35
matte99's Avatar
Trucks coming along nicely. I know what u mean about the Haynes manual, I bought one in 2002 and it has served me well over the past 13 years.
Old 12-27-2015 | 11:04 PM
  #36
zblee's Avatar
got my pushrods in on saturday. installed them and got everything else buttoned up. truck fired up and idled first try! tuning the VE and MAF tables at the moment and next thursday going to have it dyno tuned! Will get some un-tuned idle start up vids in a couple of days.
Old 01-13-2016 | 12:28 AM
  #37
zblee's Avatar
couple of more parts came in!
time to update this 10 bolt!
eaton detroit truetrac
some usa standard 4.11 ring and pinion
and a new cover to help strengthen everything
_Zblee
Old 01-13-2016 | 12:48 AM
  #38
zblee's Avatar
Updated plans:
installed:
-hptuners (installed and playing )
-built 4l60e transmission by Sean @ Top Gear Motorsports in Mesa, AZ
-speed engineering 1 3/4 SS headers and ORY (have not tested for emissions yet)
-AFR500 wideband
-efans
-tranny cooler - tru cool 40k
-Edge Pro 3600 stall torque converter
-swapped cluster for stock one with trans temp
-Walbro 255lph in tank fuel pump
-Deatschwerks 38lb fuel injectors
-AI 226cc 243 heads milled .03" 60cc chambers ~9.87:1
-AI 224/228 .610/.605 114+2 cam
-Comp Cams 7.30 pushrods
-Morel 5315 lifters
-Fel-Pro .041 ls1 head gaskets
-BTR .660 platinum dual springs w/ Ti retainers
-Trick Flow chain Dampener
-GM oil pump
-GM timing set (cam gear, crank gear, chain)
-GM Motor mounts
-ATI Super Dampener
-Stock rockers with trunion bearing upgrade
-QTP electric exhaust cutout 3"
Ordered and not installed:
-truetrac
-4.11 gears
-Moser diff cover
-caltracs traction bars
-custom driveshaft/modify existing
Waiting to be ordered:
-intake manifold?? fast, nnbs, tbss, ls6???
-new rubber??
-new wheels??
_Zblee
Old 01-13-2016 | 04:16 PM
  #39
zblee's Avatar
and this happened the other night :/
ended up breaking my Transmission Reaction Carrier Shaft . was taking off from a light and when it should have shifted into 2nd it busted and i coasted to a parking spot. had no forward gears and only reverse. had it towed to the shop the next day and this is what they found. everything else looked perfect but broke this clean apart. no metal material anywhere everything was clean. The cause - harsh 1-2 shift from removing all torque management. going to run the stock torque management and have tuner update as needed when i get it dyno tuned.
so as the shop gets my transmission back up and running I am having them install my rear end parts.
_Zblee
Old 01-18-2016 | 04:41 PM
  #40
zblee's Avatar
Shop got my tranny fixed and I also had them install the trutrac and new gears while the truck was in for repairs.
Also was able to swap my stock rims for someones replica 20x8.5 ltz rims
before
after
ended up going with a new set of Hankook Ventus ST 275/55/R20
_Zblee
Quick Reply: Project Silver Bullet!
