"Project Twister" 06 GMC Sierra Denalli crew
Old 01-06-2014 | 11:22 AM
lsxperformance's Avatar
Everything should be here this week..
Old 01-06-2014 | 11:32 AM
Vortec350ss's Avatar
That thing looks like it was sprayed with bumper spray paint... haha
Old 01-06-2014 | 11:52 AM
03sierraslt's Avatar
Instead of postponing the inevitable you should just do a 80e now.
Old 01-06-2014 | 02:17 PM
Lol the Trans is a monster level 3 out of a f body I had laying around. It took out the OD clutches so I put the z PAC in it. So I have almost nothing invested in it. Ya the center of it was painted a matte grey and I just wanted it all to match lol. It looks better than the pics make it lol. More stuff showed today..
Old 01-06-2014 | 02:20 PM
Whooo Purdy.
If you have nothing in it then run it till it breaks.
Old 01-06-2014 | 02:57 PM
Ya under 300 in Trans and stall.... Call it garage clean out- win
Old 01-06-2014 | 03:09 PM
Z PAC is a good setup there was only 6 clutch fibers in the old setup and now it has 12 and they are bonded to the steels so should double the holding capacity. So we will see how it holds up.
Kooks hooked me up with a set of long tubes as well as mid pipes so if anyone needs a set let me know! Ima dealer for them... As well as anything else in this thread. Cam kit will be avail after I have numbers.
Old 01-06-2014 | 03:48 PM
In a 60 holding capacity isnt the whole story but rather the ability of the steels to disperse heat as well. As we know 3rd seems to be the first to give out. I suppose its a catch 22, more heat causes slip and or not enough holding capacity causes it also. I always had the best luck in mine with thicker steels and less frictions vs. the opposite.
Old 01-06-2014 | 06:13 PM
TIM Z's Avatar
11 sec. Truck Mod
I would rather run a stock 60e with a shift kit than a monster with or without a Zpak . Your wasting your time /effort . Unless you don't mind swapping trans out .
But seriously you should just do an 80e like said and be done with it since you want big power.
Old 01-06-2014 | 06:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Z-pack will die quick at that power level in a truck. They warp easy from the heat.
Quick Reply: "Project Twister" 06 GMC Sierra Denalli crew
